Originally posted by: LS20
related question - how would one fix a tire that has a slowwwww leak?
mine seems to drop 10psi every 2 weeks
I had something like that before, turned out that there was a nail in my tire. The flat top of the nail sealed the hole somewhat pretty well, and so the leak was very slow. I simply went to a tire shop and they used a patch on the inside to seal it after removing and prepping the area. Patch is preferred over the plug method, and unless you have the necessary equipment, you have to go to a tire shop for it.
