Tire Pressure. when will it stop dropping and raising?
Solodays
853
it is said that tire pressure drops 1 psi in every 10 degree drop in the winter and raises 1 psi in every 10 degree raise in summer.
my questions is.. lets say, at the tires default setting at 30psi, at about what temperature does tire pressure starts dropping and starts raising? theres gotta be a temperature at which it start dropping, if not, it wouldn't make sense to say that at 50F today and 40F tommorrow you'd lost 1psi. the temperautres gotta be cold enough and hot enough in order to do so, theres gotta be a fix cold temperature and hot temperature inorder to drop and raise, if not then your tire pressure would probably fluctuate daily, am i correct?
Jahee
2,072
It will fluctuate daily yea.. just like if you've been working the tires harder, they'll get warm as will the air inside and pressure will increase..
To answer the question there's not a fixed temp it will change with and change in pressure with any increase in temp
Solodays
853
any increase in temp? 60f to 50f sure aren't that dramatic. it's hard to believe you'd lost 1 psi from there.
Jahee
2,072
Don't know the exact ratios, but a decrease of 0.1F would cause some decrease in pressure.
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
double the temp, double the pressure. halve the temp, halve the pressure. Basic thermodynamics. The 1 PSI per 10 degree drop is for people who don't know basic things like 'only check tire pressure when cold' along with knowing that there are numbers between 0 and 1.
Feb 19, 2001
20,155
23
Uhhh, you are speaking with respect to absolute temperature and FAHRENHEIT is not a scale you use when you do that. Either you use Rankines or Kelvin, but honestly, who does a freaking PV=nRT? Moreover, PV = nRT is complete absurdity because it is ideality. If you even want to talk thermodynamics, there's a lot more factors. You might need to consider vapor pressure, free energy and entropy when dealing with nonideal stuff. The Clausius-Clapeyron equation is more suitable. 1 PSI per 10 degree drop is perfectly fine. It's just like people in poker use # of outs * 4 on the flop and # of outs * 2 on the turn. It's not exact probability, but no one wants to do 5/46 * 4/45 math ok?
Midlander
2,456
Over the temperatures you are experiencing, PV=nRT will do just fine. You won't be able to measure any closer with a typical tire gauge than the equation will get you.
Just remember to use the right temperature scale.
Tiamat
14,068
At pressures less than 20 atm, and normal temperature, the Ideal gas law is a great equation to use. Only gases like CO2 start to deviate at high pressure (20 atm).
Evadman
Feb 18, 2001
30,990
Exactly. Thanks for using lots of really big words that Solodays doesn't understand and proving my point.
sdifox
100,588
17,989
Originally posted by: Minerva
It would be neat to fill tires with mercury.
err, kindda heavy no? and it probably doesn't absorb shocks as well as air. never mind it's toxic as hell.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
While it may be hard for you to believe, it's still true. Technically, _any_ change in temperature will cause a fluctuation in tire pressure, it's just that for small changes it's not a significant fluctuation.
Just driving the car causes enough heat in the tires to raise the pressure by 3-5 PSI. This is why you should always set the tire pressure after the car has been sitting for an hour or when it has been driven less than a mile.
ZV
GuitarDaddy
11,465
The car's weight would be double just because of the tires..
Not to mention the centrifical force would tear the tires apart in short order
LS20
Banned
Jan 22, 2002
5,858
related question - how would one fix a tire that has a slowwwww leak?
mine seems to drop 10psi every 2 weeks
Minerva
2,134
25
Unsprung weight does funny things. On the driven wheels it would help in the snow. Liquids in tires are bad though. Throws the balance WAY off. Hg is quite dense.
This reminds me of this thread. :Q
The best prank is to hook a decent vacuum pump up to a tire. It will assume the shape of a flower.
Chryso
4,039
13
I think you are making an assumption that there is a baseline temperature at which there is a "correct" pressure. I don't believe this is true. At all temperatures the pressure is relative.
FoBoT
63,084
15
fobot.com
yeah, to atmospheric pressure, which changes with the weather
it isn't like the tire pressure has to be exactly XX.XXXX psi
as long as it is close to a band, it'll be ok
