Eug
- Mar 11, 2000
- 24,184
- 1,826
- 126
I guess it depends on the place then. Around here 1200 square foot homes go for over half a million $.Not complicated - it keeps out the riffraff.
For not much more you can just buy a bigger house and get way more value.
a tiny house budget is 25k, a big house budget is 4x that if you live in a shit area.
Typically they start from that. Most decent ones are 40 to 60k. And then you need to buy the land anyway. And you didn't get what I was saying. If you need to build one to code to live in it full time you ware going to have to pay way more than that. Sure a cheap one on wheels is 25k. But you still have to buy land, and also you can only live in it 2-4 weeks a year. One you can live in full time all up to code and built on the land is much more.
1) You don't need to buy land if you can rent a spot on someone's property for way less
2) I got your point, the correction would be "You can only live in it until you get caught"
Here is the thing they don't tell you.
They are basically considered RV's. That's why they have to be on wheels. So they don't have to go through all the codes. You are also not allowed to live in one full time since that is the case. Probably 99 percent of the counties out there only allow you to live in one for about 2-4 weeks a year.
