jlee
When you have the shitty Craftsman and Harbor Freight jacks crap out on you in <1 year, especially in the middle of a project, you won't think $230 is crazy. That jack has a low saddle height to get under (some) lowered cars and a high jacking range to allow enough height so you can actually work under the car. It also should be rebuildable when the time comes; good luck finding parts on the rest of those Chinese POS.
I've used my Craftsman 3 ton jack for probably seven years now...
GearWrenches are awesome- they go on sale at Sears for 50% off every now and again, too.A nice to have, but not requisite, bunch of tools are the GearWrenches. There are other brands, but basically it's a wrench with open end on one side and a closed end with a ratcheting gear mechanism on the other end. In circumstances where you can't fit a socket, these make life much easier than a regular wrench
My opinion. Unless you enjoy working on cars, it isn't worth your time and money to do it yourself. Unless you make less than $10 an hour. Then do whatever you can to pinch pennies.
It also depends on the car. I've had a mechanic stick his head down by my passenger door to look at the exhaust in my MR2.
....there's no engine up there. Am I really going to take it to a shop unless I absolutely have to? Nope. 😛
heh i don't know anyone that does differently. it may be a couple 2 liter coke bottles, a milk jug, or the 5(?) liter bottle the new oil came in.
Once you've changed oil a few times, you'll have an abundance of empty 5 quart jugs and that problem goes away. 😛
