Tiger NTFS read help
Oil
3,552
Transferring about 4.4gb from my external 7200rpm hard drive to my Macbook with 10.4 took 50 minutes. I installed the NTFS-3G read/write driver for OS X but it still takes forever
Is there a better driver to use or am I out of luck?
Kmax82
3,008
www.kennonbickhart.com
Something is up with that. I had a NTFS drive when I was still using XP on another computer and it never took that long to copy files over. Maybe 10-15 minutes, but definitely not 50! Wow.. sorry I don't have any useful information to give you.. :(
randomlinh
linh.wordpress.com
Well, for one thing, you don't need the NTFS-3G driver to read NTFS formated drives. Try uninstalling and see what happens.
The only slowdown I have is most of my USB drives suck. far slower than my FW drive, heh.
Oil
3,552
I need the NTFS-3G to write though so I don't want to uninstall it. The drive itself is fast when I transfer files in Windows
SoundTheSurrender
3,126
There is another solution, I forgot what it's called but you can buy a product that supposedly fast. How are read speeds? There might be something else wrong.
randomlinh
linh.wordpress.com
Well, I was suggesting that more as a troubleshooting guide, to see if it's the NTFS-3G driver causing issues or if it's something else.
Oil
3,552
I don't know exactly what you are saying. The read speeds are slow as posted above
Oil
3,552
Well it was the NTFS-3G driver that was causing the slow read times. What do I do now for NTFS write capabilities?
randomlinh
linh.wordpress.com
Originally posted by: pinktank
paragon software is really good I used several versions of both
are you using it on leopard? any quirky issues you may have encountered? I'm hesitant to shell out money for it, as I'm very concerned about data integrity (I need one of my backups to be on an NTFS volume). I can do stuff through parallels, but having to load up windows kind of sucks just to copy data.
