ti4600 problems
zer0burn
1,485
I never said it works in xp :0 that was someone else. I'm gonna update my bios tomorrow gotta take off to work gonna get win 2000 in a few days Im in the middle of exams.
Bump for ideas here just imagine if you guys couldnt use your ti4600 come on :)
zer0burn
1,485
bump for ideas.
Like the drivers are installed just wont play 3d games I had to install drivers manually and it wouldnt reconize card.
Bozo Galora
7,271
sounds like you dont have enough mobo voltage to initialize the 3D acceleration components.
Get the biggest PSU you can find to try (430 - 550W)
Also try setting bios to 1X just to test.
Use only a single stick of 256MB or smaller RAM
Bozo Galora
7,271
and the Canopus TX25 Ti4600 card to be out in a few weeks is an attempt to fix mobo voltage bottlenecks
by allowing you to plug a molex from PSU directly into card.
i will get one of these cards, even if I have to order from Germany, just to see if it fixes all the 4X freezes/loops
(on todays AT front page news)
zer0burn
1,485
so u dont think an antec 400watt is enoguh? I only got a cdr 2 hard drives plugged in plus delta fan. My other fans arent hooked up need to fix my rheobus
