Originally posted by: nikkai
I'll vouch for the math classes not allowing you to use calculators in exams.
However, in engineering classes, a lot of them do allow it, but you have to show all your calculations anyway. It's just a quick way to get from piont A to point B if no calculations are required.
In the work-field though, the calculator is your friend. You aren't going to do everything on paper. If you do that, (points finger ala' Donald Trump) "You're fired." Waaay too slow. Of course you want to keep a record of your work, but there are just something that don't need to be done by hand.
I myself have been using my TI-85 forever and am tempted to go and grab this. But since it's been so long since I've bought a calculator, spending a bill on a calculator just doesn't appeal very much to me. Especially since I work in the pharmacy industry, haha. =P
Well put. I've got a few friends who are in EE and CE, who use calculators religously in courses - which is fine because the bigger problem is dictated by long integrations, physics involving integration and convergence/divergence, and applied Differentials. Your calc, with applied calculus (in Eng, CS, Physics,etc), is definately your friend.
My point is that those who are just starting out in basic courses of Calculus probably should not get a tool like this because it is way too tempting to use it to "just get the answer" rather than learn, for example, how/why basic integration works. I see way too many high school kids at the Community College I tutor at come in with Calc AB experience, with absolutely no idea about how an integral works, or a limit, etc.
With the basics (Beginning Calculus Series courses), a calculator like this is unnececcary and most likely will be a hinderance to you. On the other hand, as nikkai put it, in applied disciplines - your calculator is definately your friend and should be used whenever possible.
In my opinion, here is where/how you should you use a calculator:
Algebra -> Calc for statistical purposes is nice (Basic four function, or 83-85 for graphing applications).
Calculus Series (I-III) -> 83 or 85 for graphing, calculations, etc. 89
IS NOT NECCECARY AND SHOULD NOT BE USED. This series of courses is meant to reinforce fundamentals of Calculus (Limits, Integrals, Conv vs. Div, DE, etc.), and having a calculator doing the work for you does NOT reinforce these fundamentals.
Applied Calculus Classes (Eng, Physics, CS, etc) -> 89 or Hp49g+ is great when you have issues involving long proofs, integrations, derivations, etc.
