THX Speaker System
TheGeek
1,090
I am buying a new 7.1 THX A/V receiver and I'm looking for a 7.1 system to go with it. Do I need a THX Certified speaker system for THX sound? And if I do, can anyone tell me where to get one? Right now I'm looking at the Onkyo HT530 7.1 speaker system. It doesnt say its THX certified, but will it work anyways?
Goosemaster
48,775
thx is a spec that you will never achieve at such a low price point.
for the sake of your wallet, banish that term from your mind.
And those speakers are budget types but will work with that reciever.
How much do you wnat to spendon the reciever? speaks? or total?
d33pt
5,654
I think THX is pretty much hype..just a marketing scheme for lucas.
Zim Hosein
Super Moderator | Elite Member
65,527
410
Yes :)
<-- Patiently waits for the Bose lover known as YOyoYOhowsDAjello to post! :p
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
Yes :)
Well you wont get a post from me.
EDIT: crap
EDIT2: TheGeek, spending more on your speakers is usually a better idea that spending more on the receiver. What's your budget here?
A quality 5.1 vs a slighly lesser 7.1 set might be a better plan too.
Apex
6,511
www.gotapex.com
THX speakers may not be worth the extra price. That certification doesn't really add anything, it just tells you the speaker system meets a minimum set of requirements.
PurdueRy
13,837
4
THX means NOTHING(In comparison to other things you should keep in mind when buying audio equipment)
nsafreak
7,093
Another THX speakers don't mean a goddamn thing post. You can literally pay Lucas for the right to put a THX logo on your speakers/receivers/whatever without it actually being THX certified. Hell a lot of decent equipment doesn't even bother to get the certification because they don't need it. They go by the good press of the industry magazines. You don't see Harman Kardon, NAD, Denon, Carver, Renegade, Sunfire or other audio manufacturers with the THX logo on their equipment do you?
EDIT: I will post some useful info about speakers once the OP gets around to posting his budget though.
PurdueRy
13,837
4
Weird thing actually. If you look at my HK AVR 435....you can see the place on the LCD where they COULD light up THX...but it just never is....makes me wonder if they thought about getting it certified at some point and then said "Fvck it no one cares about it anyway". ;)
TheGeek
1,090
Yes :)
EDIT: crap
Im looking to spend less than $800. Right now I've picked out a $500 receiver and the previously mentioned speakers.
13Gigatons
7,461
500
http://www.thx.com/mod/cinema/about.html
THX Certified Cinemas offer movie-goers the best picture and sound available in a movie experience. THX has certified more than 4000 auditoriums worldwide which deliver optimal film presentation.
What is a THX Certified Cinema?
THX Certified Cinemas offer movie-goers the ultimate cinematic experience. Why? Because every THX Certified Cinema is designed and tested to ensure that it meets all standards for sound and picture excellence in categories such as:
Background noise ? controlled noise from HVAC units, projectors, exhaust fans & transformers
Room acoustics ? crisp accurate cinema sound through controlled reverberation and sound isolation
Image quality ? high resolution, clear images with standardized screen illumination and minimized distortion
Projection ? audience viewing angles, image cropping, and projector placement that result in the best possible picture presentation
Sound system ? THX approved equipment and alignment for optimal sound reproduction
The result is that cinema audiences experience movies that look and sound great. They enjoy:
Precise audio localization that tracks the action across the screen
A wide frequency range that delivers higher highs and lower lows
A naturally balanced sound and planned sight lines so that every seat is the "best in the house"
Accurate, true-to-life images
Highly intelligible dialog and decreased distortion
A clearer, more realistic movie-going experience
If you have visited a THX Certified Cinema recently and would like to tell us about your experience, please complete the Cinema Survey Form. Your feedback will help us ensure you get the best cinematic experience.
If you?re a cinema owner, THX certification puts you in an elite class of cinemas that enjoy tangible benefits of certification. Some of these benefits include design services, THX technical assistance and testing as well as marketing support materials. To learn more about how THX can enhance your cinema, visit the Cinema Certification section.
http://www.thx.com/mod/services/homeCertOview.html
http://www.thx.com/mod/services/CHTTechnicalOverview.pdf
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
Yes :)
EDIT: crap
You should try to switch your budgets.
A $250-ish receiver and $500 speaker/sub would be a better idea than a $500 receiver with $250 7.1
PurdueRy
13,837
4
Yes :)
EDIT: crap
^ Agreed
Apex
6,511
www.gotapex.com
Yes :)
EDIT: crap
I'd grab the cheapest 5.1-7.1 receiver I could and then spend the rest on speakers.
Here's the one I'd grab:
Info from Pioneer about the VSX-515K
Pioneer VSX-515K 6.1 Channel A/V Receiver with 110w/chan, DTS-ES, DD EX, DPL IIx for $175 plus 6 cents shipping
That gives you $625 to spend on speakers.
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
Is this for music or movies, TheGeek?
mix?
If you're willing to get refurbished, you can get a pretty solid receiver for under $200.
I'm on hold with ecost right now checking how much this Pioneer 815 costs....
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
Booooo!
The 815 comes up as the cheapest receiver if you sort by price, but it's
1. not in stock
2. $249
TheGeek
1,090
OK. I appreciate all the advice. But will a non-THX certified system system sound the same as a certified one? And can non-THX systems upmix 5.1 to 7.1?
DarkKnight69
1,688
I agree, i spend $3500 (all polk audio) on my speakers and only 500 on my reciever (Lower end HK so still nice). It sounds incredible. Hih end speakers will do a better job of hiding crappy reciever then a high end reciever will of hiding vrappy speakers!
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
No, no speaker / receiver will sound exactly the same as another one. This doesn't mean better or worse.
At your pricepoint THX shouldn't be something you're considering.
A non THX receiver that supports DDEX should be able to give you 7.1 (mine sure did).
I haven't checked on my new receiver that happens to be THX since I went from 7.1 down to 5.1
7.1 is not a big deal over 5.1
Do you have a good room for 7.1 placement (DDEX)?
TheGeek
1,090
What about THX-certified movies and games. will they sound the same with a non-THX receiver?
