Question Threadripper 2990WX cooling
resle2
Hi,
with no intention to overclock, and obtaining the lowest cpu temp possible as the only goal, what cooler would you advice for a Threadripper 2990WX?
The only solution I can't manage to adopt, is a custom loop.
Thanks
Having this guy sit right smack next to your case with side panel open on a noctua TR heatsink.
https://www.newegg.com/p/N82E16896268134?Description=rosewell portable ac&cm_re=rosewell_portable_ac-_-96-268-134-_-Product
You may need to elevate your case on a pedestal or something tho, so it gets the direct air flow.
no seriously why do you want the lowest possible temps when your not overclocking?
But being serious that AC blowing 60F air into your case will net you the coldest possible temp outside watercooling.
You have 2 choices, about the same, the wraithripper and the Noctura made for the TR4, I can't find the model number ATM, but you also need 2 fans for that one.
