Question Threadripper 1950x problem
videoeditor123
4
My threadripper 1950x freezes whener its doing heavy workloads in creator mode. when i set it to game mode its all okay. I want to use the creator mode because the performance difference in premiere is huge.
Has anybody experienced this before? how to solve it?
SamMaster
188
137
Maybe something with the RAM? If I remember correctly, game mode disables half the cores and half the memory controller, so half the RAM (the sticks connected to the second half). Someone can correct me on that.
videoeditor123
4
Might be the issue, i have a total of 64gb ram. but when i pull out 2 of the sticks. so im left with 32. there is no problems at all.
I have bought 2 x 2x16 kits. same brand , same speed and everything.
I read that you should buy kits with 4 or more. But in the manual it even says that it is okay to mix Ram speeds. so i cant be that sensetiv to ram sticks?
Any way to fix the problem? by tweaking in bios? or in ryzen master?
Hitman928
6,753
12,492
Is this something new that just started happening or this is a newer system/configuration? What speed is your memory set to?
videoeditor123
4
i just bought a new kit with ram. have been running with 32gb past 2 years.
I thought it maybe occured since the ram sticks i already had was 2x16 2666 (1.2v) and the newer ones was 2x16 3200 (1.35v) then i bought another set of the 2x16 3200 the day after. but the issue is still there.
I can run smoothly with all sticks placed inside - 96gb in game mode. That is all the above mixed. But as soon as i switch to creator mode and do some heavy lifting. the computer freezes. ( also freezes with just the 64gb of the same type inside )
in bios it is set to standard.
Hitman928
6,753
12,492
Have you tried running the full 64 GB at 2133 MHz? The more slots/ranks you have the harder it is for the memory controller to run at higher frequencies and the first gen Zen memory controller was not particularly strong. I would try running at 2133 MHz and see if you get the same result. If the freezes go away, maybe try 2667 MHz and see what happens.
Reactions: videoeditor123
cellarnoise
859
450
Sounds like ram? I started out with two different speed ram from same vendor (Gskill) on was older and like rated at 2600 and the other was newer and fast at 3200 cl14. Could not run it above 2400 or so without errors. Bought another 3200 g skill cl14 set and have been running 3200 at cl14 tight timings for a few years now.
I would start at slowest ram stock timings and speed and check for errors. Even that may not work as most don't recommend mixing any kind of ram brand, speed or timings, especially at 4 channel from what I have read on amd first gen threadripper. After initial ram brand blending and speeds, I am still running my 1950x 24/7 after several years and same brand ram and tight 3200 timings. But only max 32gb in all instances.
Good luck.
lightmanek
524
1,287
Take your CPU out and check visually socket for bent pins. Reinstall your processor if all is looking good, make sure you are following the numbers on the bracket when fastening screws. Threadripper can be unstable if not secured properly.
Also, what speed are you running your RAM at with new sticks?
I had 1920X before and once had stability issues at random, reseated CPU and that resolved my problem ;)
Hitman928
6,753
12,492
Seems like lowering the speed of the memory in bios fixes the problem. doing some testing now.
Yeah, most likely the memory controller just can't handle that much memory at 3200 MHz. Hopefully you will at least be able to get 2667 MHz out of it.
ajc9988
278
171
Ok, first do not run 96GB, please. So the 64GB at 3200 sets.
Second, mixing and matching speed can effect timings, as each set may need different amounts to work as well as different voltages.
Third, if stable at lower MHz, you may just have a weaker memory controller on one of the dies. You also could just have a situation of incorrect timings for Ryzen gen 1 in the XMP settings, so it trips up once in quad channel.
How long do you have that you can take the machine out of commission? What knowledge do you have for ram overclocking? How familiar are you with ram stability testing?
It could even be the SOC voltage set wrong (sometimes lower is better; like if I set over 1.05V on LLC level 2 SOC, I lose stability on my system with my 32GB at 3466 CL14).
So it really is a situation of needing to know timelines, familiarity with the process, etc.
B-Riz
1,595
765
Was this ever resolved OP?
When I setup my 1900X system (4 channel x 8GB), I set RAM speed and timings manually and, I have never ever used auto memory profiles on any AMD Zen1 / Zen2 / Zen3 products, it never passes stress testing for me.
