DrPizza
Usually, when you start using a garbage disposal for the first time in your life, you make a few discoveries.
1. If you peel all your potatoes, then put the peels down the garbage disposal when you're finished, you're very likely to end up with a clogged pipe.
Not a problem - very easy to unclog, especially if you just take the trap off beyond the garbage disposal.
But, if you have a tenant & they decide that it needs the attention of a plumber, being out of state, it's going to cost you. Personally, I wouldn't make that convenience available for a tenant (speaking as a landlord who has been summoned for at least 5 clogged drain issues within the first year of renting out my old house.)
