Originally posted by: Sahakiel
Originally posted by: SuperTool
That's what I mean. If you look at centrino, about 1/2 is L2$, so the core size minus L2$ is around 45mm2.
If you look at P4 core, around 1/6th is L2$, so the core minus L2$ size is about 120u. That means you can put about 2 centrino cores and more L2$ than P4 on the same die that you can put just one P4 core and less L2$. Which one do you think would have better overall performance, single cpu P4 or 2 CPU CMT Centrino, provided that single processor centrino performance is very close to that of P4?
First off, I don't think Banias has multiprocessing support.
Second, I don't think Banias has HyperThreading.
Third, I don't think Banias has a trace cache.
Fourth, I don't think Banias supports PAE
I can't seem to find information on Banias' pipeline depth, though estimates seem to put it between 10-20. My guess is it's closer to 20 than 10, but including x86 decoding.
I also don't know how many instructions in flight Banias can support.
What's my point? Simply that both cores are different from each other and it's difficult to tell whether you could even get two Banias cores to work together. You might as well compare Pentium 4 to Athlon and see if you can go dual-core Athlon with shared L2 cache on the same die size.
