This is not a toy!
Rubycon
Madame President
Aug 10, 2005
17,768
485
Easily packed with video/audio equipment. A pair of slugs slipped inside a rabbit's foot attached to a keychain that gets put in the tub with your wristwatch, cellphone, wallet, etc. ;)
Except those pesky metal detectors.
Linflas
15,395
78
How many times have you heard that yet you know...you just have to have/build one?
Lasers come to mind obviously.
So do coil guns!
Check this one out.
http://www.youtube.com/watch?v=7LjnhhtHojM&
:wub:
I still remember in 7th grade when the firemen came in to give us a safety lecture and showed us the hair spray torch accompanied by the "don't try this at home" lecture. I guarantee at least 90% of us immediately went home, grabbed mom's can of hair spray and tried it out ourselves.
Fear No Evil
5,922
Contacting homeland security on you now. Please wait at your door with your hands up. :whiste:
sdifox
101,153
18,197
It has plenty of power - it's portable, won't set off any security systems (no explosives) and can destroy a server. ;)
I've been shot with one of those nerf guns. Would you want to get shot with that? :biggrin:
Yeah he was shooting at a toaster oven and his weapon has a laser sight. It could have bounced back in his eye. ;)
err, it could not puncture that plastic plane. Which means it is lacking in speed. It will not touch a server.
Rubycon
Madame President
Aug 10, 2005
17,768
485
I did that with WD40. :biggrin:
Even better is light a candle and step back about three feet and point a butane can at it and depress the valve. If you're in a tight room something will move from the air pressure change! :eek: The first time I saw this done three panes of glass in the overhead door what were moved - right out of the frames falling free to the ground where they shattered! :eek:
Like they really care about someone's Lone Ranger rabbit feet. That's why the main caps should be Rubycons. (or at least Nichicons) No questions asked admittance. ;)
Oh I think it will. Just to add to fun attach a small wire and connect to 240VAC circuit, remove server cover and shoot at RAID controller, etc.
Turning off the server and pushing a "pillow" of steel wool behind the CPU socket area and replacing the cover is another trick. The unsuspecting nerd turns it on to see smoke. Lots of it! :biggrin:
Let's face it! That gun is hardly a weapon to hit the streets with. Same with airsoft and other bb type guns. They're plinkers. Show up to a meet where others are shooting paintball, airsoft, etc. with that thing and you'll certainly turn some heads.
JTsyo
12,067
1,159
Wow this didn't make sense until I realized you put the quotes under your response.
