This is getting annoying...wireless does not work unless I fidget around with it
lektrix
1,174
One month ago I had a DI-624 router & SpeedStream 6520 DSL modem (Bell branded so I flashed it with Siemens firmware). I realized my SS6520 had router capabilities as well and I was actually running both routers together so I gave my DI-624 away.
Turns out it was a bad decision because my sister's wireless hasn't worked on consecutive days for about 3.5 weeks. Her PC is on the top floor and my router/modem is in the basement (she uses a DWL-G520M 108G MIMO Wireless Adapter).
Whenever she turns on the PC, there is no wireless connection. What should be an automatic 2-3 second connection takes 5-10 minutes as I have to go into her profile and refresh/connect to the right wireless AP or remove/add the wireless profile...
AFAIK, all the wireless settings are correct and match up...i'm using Channel 11 (tried 6), Broadcast SSID, WEP-128bit HEX password, Open Authentication..don't have any 2.4GHz cordless phones near the router or PC........
What is going on?
Modelworks
16,240
7
Either what JackMDS suggested or spend the money to wire it with cable.
Another option , though costly, is to go with 900Mhz wifi, it can penetrate brick, wood, and several floors.
