Thinking of going dual monitor if it meets my expectations...
jEct2
1,726
I thought I'd post it here since I have multiple questions about TV tuners & going dual monitors, all current dual monitor users are welcome to provide information.
I currently have this (received editor's choice @ Tom's)
I'll be moving out soon to live on my own. I'm thinking of buying another one. The number one reason why I want to go dualie is I'd rather spend another $400 for a dual monitor + TV tuner setup than having a separate TV. But I don't know a thing about how everything will connect to each other... I'll just start with questions:
Connectivity
1. Is this even feasible? My videocard (Geforce Ti200) has only one plug which is obviously occupied by the current monitor. If I buy another LCD, where does that one go? Do I have to spend more $$ on a new or additional videocard?
2. Do I need an extra cable outlet from the wall for my TV tuner?
3. Just how does everything connect to each other? Two monitors, one video card & TV tuner card!??!?
Fuctionality
4. With the dual setup, I'm still limited to playing full screen video games & watching DVDs in single monitor correct?
5. Can I watch TV with one monitor fullscreen while I use my PC on the other monitor?
6. Can I watch TV with one monitor full screen while I watch DVD/WMP movies on another?
7. How much does DVI make a diff? (on either single or dualie setup) I'm currently using analog. I hear it's more placebo and analog is perfectly fine...
TV Tuner
8. What do you recommend? What do I need to take advantage of High Def screen? I hear Hauppauge is good.
9. How much should I spend? Diff between hardware/software recording is just CPU usage and not quality of the video right?
Overall
10. Do you think it's wise to spend another $400 for a dualie? Wouldn't it be just that expensive to upgrade my monitors in the future since I have to replace two? (I'd hate mismatching monitors...)
11. Anything else?
Thanks!
dug777
24,778
4
firstly u need a new gfx card, and secondly, duallies>j00 ;)
they are awesome, once you use a dual monitor setup for any length of time, you can't go back ;)
JustAnAverageGuy
9,057
Yes
You need to plug your tuner into SOMETHING ;)
Yes, you may be able to get around the DVD part with some tweaking though.
Yes
With some tweaking, yes
Depends on the monitor. DVI almost ALWAYS looks better though.
Then make your first choice a good one.
11. Anything else?
Yeah, wrong forum :p
notfred
38,241
4
Yes, you need a new or second card
Assuming the TV tuner is a PCI card or USB accesory, then no, it should work fine the way it is
I don't have a TV tuner, but my setup is two monitors on a desk, each with a cable running to a video card (one video card with two connections). It's not very complicated
Fuctionality
4. With the dual setup, I'm still limited to playing full screen video games & watching DVDs in one monitor correct?
I've seen it done on two, but DVDs with a big bar in the middle from the monitor bezel looks really crappy.
Yes, same with DVDs.
Assuming your video card can handle it, probably.
I can't tell a difference by looking at the two
TV Tuner
No idea about TV tuners
see last comment
Overall
Not if your primary reason is for multimedia stuff
11. Anything else?
I use dual monitors for development and graphics work. I can have photoshop open with one monitor dedicated to a workspace, and all my tools on another monitor. Or, I can have visual studio open on one monitor, and a web browser open on the other, so I can test the site I'm building as I work on it.
It's kinda pointless to do it for multimedia reasons. You can't watch two movies at once, and you can't read ATOT while watching a movie. You simply can't pay attention to both at the same time. If that's what you want to do, you'll quickly realize that while it looks cool to have al lthat stuff going on at once, you don't actually get any benefit from it.
RossMAN
Grand Nagus
Feb 24, 2000
79,044
445
Now I'm tempted to hookup my Dell 1900FP using analog for some dual action.
jEct2
1,726
What's a good dual monitor video card for about similar performance to GF3 Ti200?
Aug 26, 2004
14,685
that the truth...i feel incapacitated on any other computer with only a single lowly monitor ;)
jEct2
1,726
Originally posted by: The Boss
why go dual when you can go triple ?
:beer:
Only if I had $$$....
It seems it'll be pretty expensive...
LCD monitor $400 + TV tuner $70 + NEW videocard $100-150 = :brokenheart:
jEct2
1,726
Yes but then again, even for sole multimedia purpose, I think having a dual screen that you can use for both TV AND PC usage is better than having a $400 stand-alone TV. When the TV is off, you get to use that space for PC, which you can't do with stand-alone TVs.
You also get to take advantage of the existing PC sound system that you have instead of listening to the crappy TV speakers...
Snapster
3,916
No, you can buy a splitter cable if you want to be cheap and run dual on the one card/one output. Performance is reduced though, so a second card is advised.
No, it should be controlled via software anyway just drag the viewer onto the monitor you wish.
Two monitors, either connected to the one card(dual or single + splitter), or one card each.
Fuctionality
As someone has said, it's possible but it requires the software to support it and has the drawback of the inch of monitor in the middle.
Yes
Yes
Most wont notice the difference, some monitors have a visible richness difference when using DVI compared to analog though
TV Tuner
I've heard that as well, but I don't currently run one so I'm not best placed.
see last comment
Overall
Steep fee if you just want to join the 'in' crowd in having a dual setup.
11. Anything else?
Benefits are for development/graphic work imho, other than that it's bragging rights
Mo0o
24,227
DVI makes a BIG difference. It's one of my regrets of not having a dual DVI video card.
imported_Phil
9,837
No-one seems to be understanding this bit.
Yes, you will need an extra cable outlet from the wall otherwise you haven't anything to plug into your TV tuner card.
oogabooga
7,806
i have a 2005fp and have a 15in lcd that i *could* use with it : but i choose just to single display.
you will need a video card with dual inputs (2xdvi, dvi+dsub, 2xdsub, etc). Or you might be able to plug in a pci video card, but realistically, one card with two is probally a lot less work in the long run.
You can watch tv on one and browse the other : I haven't able to run a game and watch tv (though i really really wanted to :p ) I didn't really tweak too many settings so it might be possible, but i just ended up having another computer run tv video while i play games (which is the comp the lcd is connected to)
with the tv tuner department : i have a wintv-pve by hauppauge. I think a pvr250, it's nice : works well.
dual display is nice : But really probally not the most neccesary thing ever, and unless you have cash to burn, i probally wouldn't. Would i dual display 2005fp's.. probally if i could : but i wouldn't drop extra cash.
Mo0o
24,227
You can get quite a large tv for 400 bucks and you would be able to hook it up to any video card to play movies. That's another option.
