Thinking about going GTX 570 SLI
and you do not want that MSI gtx570 anyway. they have cheaped out and gone back to using the crappy gtx470 cooler.
Thanks for the info... I had a GTX 470 before I EVGA step-uped to the GTX 570... my former GTX 470 was sitting over 100 degrees C with fans at 70% and the fan was LOUD!!...
my current GTX 570 sits at 65 degrees C with fans at 70% and the fan is not as loud as the 470's...
No it will not. Only crossfire.
EDIT: I'm not sure which models, but only the latest AMD motherboards have been certified for SLI support.
**SIGH*** thanks... if I go with a new Mobo I might as well go with a new CPU... if that is the case I might as well wait for the new generation of cards...
You have a bottleneck with 570, your CPU is holding it back. You would see more FPS higher FPS with a better CPU. So going SLI your gonna get weak results and its a waiste of money. Stick with what you have, one day when you get a new mobo CPU... system, u can then go SLI ! dropping 2 x on a Phenom Q 3.4 is like throwing it on a core2duo or a non ocEd quad system.
Found a GTX 570 for $249 after rebate here:
http://us.ncix.com/products/?sku=57383&vpn=N570GTX%2DM2D12D5&manufacture=MSI%2FMicroStar&promoid=1367
Will my current MOBO support it?
I know I need a new PSU at least...
Thinking about trying to get max eye candy for BF3...
I think he should be OK with that CPU at 1920x1200 res.
er.. for a single card. SLI it may indeed be somewhat of a bottleneck.
cpu is plenty for a single gtx570 and not too bad of a waste for gtx570 sli at 1920 if you actually crank every graphical setting and use plenty of AA. was the res even mentioned though?
28" monitor in sig mentions 1920
