Think Nintendo will make a home-only Switch?
Cozarkian
1,352
95
Great vid from DigitalFoundry. Good examples of the present technology in use, and possible future upgrades.
Seeing the Minecraft example (appx. 3:30 and 8:30 in vid) it really got me thinking about this again though. The Switch runs Minecraft at a noticeably higher block distance view when docked vs portable... so it might make some sense to have a constantly-high-performing and small-sized Switch-compatible home console. If it were within 50-70% of the cost, I'd buy one without hesitation.
It is still wishful thinking. If nintendo decides to make a console only version it will probably cost more because it will be a more powerful system, perhaps with 4K.
Blue_Max
4,223
153
...that seems a bit more of a stretch than my own idea! No way would compatible software go from a 720P Switch to a 4K console... even 1080P is a stretch!
You're talking a whole new console that would be compatible with Switch, but be something more on top of that.
...hey.... that's not bad either. Something backwards compatible, but have dedicated console-only software over and above that. Fun idea, but it makes more sense as a business model to have the critical element, software, as broadly used as possible.
...hey, it's all pipe-dreams either way. ;) I just never realized how big the performance difference between plugged-in and mobile was!
Cozarkian
1,352
95
I thought it already does 1080p when docked? Hmm.... a quick google search indicates some games can do 1080p, while others (Zelda) are only 900p.
To refine my idea, maybe Nintendo could just make a Dock Pro that comes with a powerful video card in it and upgrades the current switch?
Sonikku
15,908
4,940
The thing is a cheap piece of plastic Nintendo wants $80 for separately. If it had a video card in it I could not even imagine what Nintendo would want for it!
poofyhairguy
14,612
318
Actually the dock set is $90. I know that because I was ecstatic to be able to buy one for $75 (plus tax) recently. It is overpriced but it is cheaper than having a console for each of my tvs.
Zenoth
5,202
216
No. I'm 100% convinced that they won't.
However, I'm 99.99% convinced that they will 'follow suit' with the new mid-generation upgrade bandwagon and will eventually release some sort of a Nintendo Switch Pro / Plus / [insert gimmicky word]. And that one, I'm sure, will at the very least be "more powerful" in docked mode if anything (but most likely so in undocked / portable mode since that's the real incentive of the Switch). I'm also fairly convinced that if they do make such an upgraded Switch in 2 or 3 years from now that they'll also give it a redesigned dock. But time will tell.
JujuFish
11,457
1,058
Nintendo wouldn't be following suit. They started the trend with the 'New' 3DS. Or perhaps even further back with the DS Lite or DSi.
Reactions: CZroe
