Hello everyone. I just recently recieved all of my components to the new computer i am building and i must say its a beautiful system. Well the Tai- Chi case with pre installed watercooling is what im using for it.
http://www.newegg.com/Product/Product.asp?Item=N82E16811133171
Well i got all the components in, the waterblock installed correctly and i followed all the directions like i should have. Well when i first went to fill the case up i did as it said and filled the resevoir and turned the case on. the water seemed to go through the tubes and i kept filling. Long story short its filled now and should be working correctly but im having a problem. When i turn the system on i can see the water begin to flow because it moves through the tubes a little bit but im pretty sure its not flowing like its supposed to. Im using xp + coolant. Im new to the whole watercooling so im learning as i go. The pump is hooked up and all the leds and fan on the radiator come on. I can tell the waters not flowing though because i can also see air bubbles just sitting in the tube. im pretty sure they should be moving. I also know because the temp on my cpu keeps rising. I always turn the system of when the cpu rises to 60 degrees Celsius though. I mean i havent even installed an operating system or anything. just plugged the case in trying to get the watercooling to work. I usually sit there and watch the temp steadily rising and the alarm sounds at 60 so i figured thats the time to turn it off. PLEASE! someone help me. I really want to get my computer up and runing but like i said im a noob to watercooling. and i just need to know what to do about the pump or maybe checking to see if its working correctly. Of course i emailed thermaltake..... but lucky me the bastards dont have a tech support phone number. email is the only option... thanks everyone
