BonzaiDuck
- Jun 30, 2004
- 16,617
- 2,023
- 126
Well . . . if the thermal resistance is lower, it's going to cool better . . .
That doesn't mean that the Ultima 90 is the "best," but I suspect, the way TR designs their products, it will match U-120-Ex performance.
Couple years ago when the XP-120 hit the street, there were issues about interference with capacitors around the CPU socket for certain boards, and the side of the XP-120 would make it difficult to fit a heatpipe cooler to the VGA card. They put out the XP-90 and 90C, because it addressed these clearance problems.
Some people are going to be put off by the IFX-14 or the U-120-Extreme because of the size of the cooler. The coolers are tall enough, they may not clear the side access-panel of the case for some narrower midtowers cases. So I can see some enthusiasts wanting a cooler like the Ultima-90 to resolve that problem.
On the matter of the Ninja, it turned in performance benchmarks that were close to the SI-120 per Citarella's OverClockers.com review. It was interesting to see that with a fan speed of just over 800 rpm (using the same fan on both coolers) -- the Ninja outperformed the ThermalRight cooler by a narrow margin, while the ThermalRight trumped the Ninja when the fanspeed was set between 2,200 aod 2,500 rpm.
But imagine how those fanspeeds are going to be useful. People who are absolute noise-phobes are going to run the lower fan-speed regardless of the Scythe cooler's thermal resistance at that speed of something close to 0.2 C/W, while those users who want the performance when it counts will thermally control the fan on either cooler.
I myself had considered getting a Ninja, only because it can pull air through two adjacent sides of the fins in a small midtower case, and in some such cases, would fit near the exhaust fan and PSU intake fan like a glove.
