I have two bad cards, a MX4000 and a FX5500, both due to overheating. One due to under sized heatsink and the other to a bad fan. Do the GPUs have thermal protection? If so, they should be fixable? Right?
Probably not but you should be able to pick up a spare MX4000 from Ebay for very cheap. I might even have one lying around somewhere.
Probably a good idea to make sure your case has good airflow, a heatsink on it's own won't be ver effective if ity has no way of cooling as heat will just build up.
