have to be a brave mofo to eject..
The rotors will be blown off by explosives first before the pilot ejects
really ? which way, sideways ?
"The Ka-50 is the world's first operational helicopter with a rescue ejection system, which allows pilot to escape at all altitudes and speeds. The K-37-800 Rocket Assisted Ejection System is manufactured by the Zvezda Research and Production Enterprise Joint Stock Company in the Moscow Region. The seat operates by pulling the pilot from the helicopter cabin using a solid-propellant rocket motor. The system comprises the seat, a control unit and a pullout rocket motor. The seat is fitted with a survival pack containing an NAZ-7M survival kit, a life raft and a PS-37A parachute system. The seat provides safe forced emergency escape from helicopters in the speed range 0 to 350 km/hour and at altitude 0 to 6,000 metres. The seat also provides safe ejection during inverted flight (at speeds 0 to 330 km/h with zero vertical velocity) at a minimum altitude of 90 metres. Pilot is ejected in max. six second."
http://www.military.cz/russia/air/helicopters/Ka_50/ka50_en.htm
no thanks keep your ex soviet junk..
AH-64 is by far a superior aircraft in aerobatics suvivablity and avionics and wep systems..
the only weakness to the OLDER Apaches was indeed sand killing turbines.
How about you come up with some numbers first before bashing all Russian Weapons are junk?
every single wep system the Soviets had they stole from us during the walker spy case and before..
you didnt post 1 number nor have you served in either the US or Soviet armed forces.. I have been inside and seen what Apaches can do close up in the 10 years with the Armed Forces.. (join US Navy/Army ops) have you ever worked on a Werewolf? no one in the US has.. infact the POS isnt even combat proven yet.
look at the avionics package for the Werewolf.. ALL analog.. no advanced avionics at all..
look at the Longbow Apache.. able to track up to 6 targets at 1 time from behind cover and destroy them all without even being seen..
there werewolf is incapable of this.. it is a knuckledragger fighter in your face.. and Soviet missles have always been notorious for having issues. and its cannon is fixed along side the aircrafts body.. the Apaches 30mm is on a turret thats guided by the gunners helmet what he sees dies...
The KA-50 has it too. Plus you can get it equipped with third party avionics if that's your preference.
# The HOKUM uses a low-light level TV or thermal sighting, a laser range-finder (10 km), FLIR, air data sensor, and digital data-link which interface with a fire control com-puter, an autopilot,
a helmet sighting system and HUD for target location, acquisition, designation, and firing. Night/Weather Capabilities:
# This aircraft?s avionics package ensuring a full day/night, all weather capability. If it is to be employed at night in an attack role, it must be fitted with a night targeting pod. This pod includes a FLIR, a millimeter wave radar, and an electro-optical sight takes up one of the underwing pylons. The Ka-50N, and Ka-52 are capable of performing attack missions in day/night, and all-weather conditions.
# The French companies Thomson-CSF, and Sextant Avionique offer nav/attack systems, which can be fitted to export variants.
