Jeff7181
- Aug 21, 2002
- 18,368
- 11
- 81
Originally posted by: rabidoverclocker
My 2.4A runs at 44C idle and 52C-56C under full load at 1.7 volts (which is always around 1.55-1.6) on my AI7. All of you saying 1.7 vcore is too much are most likely amateurs...
Im using a custom watercooling setup w/ a DTEK Whitewater. There is no advantage upping the voltage past 1.7, it does not yield any overclocking benefit.
I can run this chip @ 3.8 (1.8 vcore) but i keep it at 3.6 to keep the temps/workload on the mofsets down.
I've used my AI7 problem free for about a month, most of the time running prime95 torture and it gives me no problems.
I went and got a new MSI 865PE NEO2-PLS and set it to 18X200 (3.6ghz) with 1.6 vcore and the motherboard failed (burnt mofsets) just like the other one in less than 30 minutes under Prime95 Torture Test.
This AI7 can handle fine what TWO brand new MSI boards could not...go figure...
If you guys can't see lack of quality on MSI boards "supporting" the Prescott then that's your deal. You can physically see they skimped on the power regulation just looking at the board compared to the AI7. The solder points on the MSI board show they used only HALF of the capacitors, mofsets, etc. that the board was originally designed for in order to cut cost...and ultimately ruinined the quality of the board for serious overclocking...
You won't see ABIT, ASUS, etc boards burning up like this...
Well there goes your credibility...
"increasing voltage past 1.7 doesn't yield any gains" ... "if I increase the voltage another .1 volts I get 200 MHz more"
