namelessentity
- Oct 8, 2005
- 63
- 0
- 0
Wasn't the towel trick a bad idea though? If you send it back working they're probably going to assume you're an idiot and send the same console back to you.
ROFLwaffles, thats it, the bear has mad repair skillz.![]()
Reading around, it looks like the leading theory is that it remelts the crappy solder on the GPU, allowing it to make contact again. It is stated to be very temporary, so I hope that box shows up this time.
Originally posted by: hans030390
Originally posted by: Kirby64
Sorry to crap on this thread, but the towel trick is just a cheap, crappy method of bandaiding a console on it's way out. All it's doing is HOPEFULLY remolding the solder on the BGA joints, to make it run. But if you already got the RROD, you'll get it again sooner or later.
The only good real fix is the X-clamp fix. It gets rid of the issue of the flawed x-clamps and solves your issue permanently.
I wouldn't call it a permanent fix yet...I don't think there's been enough data to say if it solves the issue permanently or not. The results for now, however, seem to be great.
It's certainly the best fix I've seen yet, barring crazy stuff like a complete lead-solder replacement on the GPU BGA.
There will never be a permanent solution, as the base hardware design by M$ is just garbage. the GPU heatsink isn't big enough, and the mainboard is too weak. The board flexes under all the heat, and the X-Clamps don't provide enough pressure to stop that flex.
