Goodnight in about 10-15 minutes!
3mg is a pretty large dose. Probably unnecessarily large?
Jesus can't Americans do anything without being medicated?
I have the exact same crap. It doesn't do shit for me.
Take the whole bottle.
I wonder if the bottle has a warning on it.
warning: this bottle contains enough medication to make you really sleepy! take only if you want sleepy. do not attempt sex after taking this medication. this medication does not make anal sex easier.
Yeah, although New Zealanders apparently can't post without bitching about Americans.
http://www.nutritional-supplements-guide.com/vitamin-b6-overdose.htmlI prefer valerian root. and you can't get vitamin poisoning from b6.
People taking large dosages of vitamin B6 (pyridoxine) on a regular basis for an extended period of time should be aware that problems can arise. There is a potential for damage to your nerves, but in most cases it is reversible.
Symptoms that you will notice first with a vitamin B6 overdose are numbness and tingling in the hands and feet.
You may also notice a loss of manual dexterity and your balance may be a bit wobbly.
People have been known to form kidney stones when they have taken excess vitamin B6 for extended periods of time as well.
Taking a multi-vitamin with the correct dosages of each particular vitamin is one way to avoid an overdose and ensure that your body is getting all of the nutrients it needs...which is not always possible through diet alone.
I've never seen a smaller dosage. I have seen 9 mg tablets and the 3 mg tablets that I have right now gives a dosage of 3-9 mg.
The SO takes 1mg tablets.
The recommended dosage is far below 9mg, iirc. The body creates less then 1mg of melatonin, I believe, so you are supposed to start out below or at that point, and only up the dosage if you do not experience any effectiveness.
