Originally posted by: robisbell
Crusty,
word of advice do read all the posts before spouting off childish insults and unwarranted opinions.
per the OP
"Timing from hitting enter until Ubuntu was ready to use went as follows:
4gb RAM - ~3m35s
3gb RAM - ~2m20s"
Originally posted by: daveybrat
You don't want to leave him with 3Gb of ram. Then he won't be running in dual-channel mode like he is currently. You either have to leave him with 2x1GB sticks or but 2x2GB sticks, but do not use 3 sticks of ram in there. You'll degrade his performance.
2GB is pretty decent for WindowsXP and he can always swap them out with 2GB sticks down the road sometime.
they 4th stick will no be used by the OS in any way shape or form, and it does slow down the boot process leaving it in, bu sped up the process with the 4th stick removed. A 32bit can not use 4GB of ram, and whomever told you in theory it can, was absolutely wrong.
I'd be extremely honest with the customer and explain it again that leaving the 4th stick in that is never going to be used by the OS he's using will slow the system down, I was told telling the truth made customers trust me more, even if it was news they did not want to hear. I'd tell him the facts, be totally honest with them and lay out all of the facts for them to make a honest decision.
thraxen, you're omitting that you have to hack the OS, first, then you have to find programs that can make use of the hacks to access the last 1gb of ram. you have to use PAE from 4GB and above. everyone omits the fact that the system ran faster with only 3GB versus 4GB, but, I've tried to make them see the whole picture, and you all only see parts you choose to see, and not the whole thing.
yet if it's a flaw in the design of the car that shifting it into 6th and there only way to fix it is to upgrade the transmission then you tell them that, if they do not want to, then there's nothing that can be done. trying to shoehorn a fix for a known issue and expecting miracles and not being upfront and giving the customer the facts, is the problem with you. if the owner doe not grasp the problem, then you need to explain it till they do, I've had to explain to people, spending hour or more till the proverbial "lightbulb" comes on and they understand.
yes they paid for the 4GB ram, but they skimped on the OS, and you could try the hacks to make the OS see the 4GB VIRTUALLY ( not physically), and then the customer will have to find software versions that can use the hacks of the OS.
like i said, they have a issue, but they do not want to pay for the cure, they want a patch job and expect a 32bit OS to run like a 64bit OS. I think whomever sold them the system and OS's is the one to blame for this whole situation, but all I can say is that they can either take patch jobs and find versions of programs they will be using to make use of the virtual 4GB, or they can pony up for the 64 bit versions and have full access to the ram.
I'm done explaining the facts, and if the OP wants to keep going blindly down the path of patching the problem, good luck.
