- Jan 2, 2006
- 10,455
- 35
- 91
Originally posted by: ST
Updated, thanks!
Originally posted by: akugami
Good points. Updated
Originally posted by: MyStupidMouth
Buy a 300 wat bestec PSU and smash it on your 7900 and oc it toi890/880
troll much fanboi?
troll much fanboi?
Nah i own a 7900gt. cry more.
Originally posted by: WT
fuzzy, would you recommend the 1.3v mod on a GT card with a standard heatsink and RAM cooling ?? I am in line for an EVGA 7900GT SC and it appears to be using the standard 7600GT HSF. I am not against buying an aftermarket vid cooler, I just prefer to keep the card as close to stock as possible (even tho EVGA warranties it with an aftermarket cooler!).
Ohh, and great post and guide as well.
If you want a cheap aftermarket cooler, just get the NV Silencer.
Originally posted by: secretanchitman
sticky vote and what a great guide!
Originally posted by: fuzzybabybunny
or Harbor Freight online. If you get the RadioShack multimeter make sure to purchase a 12V battery at the same time because it doesn't come with one. I'm not sure about the Harbor Freight one.
Also, you might want to add this into the OP cause some other people are also having this problem and I think I found a fix to it.
Some people after they do their voltmod's, can sometimes get the video card to make the screen go in and out (like turning black then going back to desktop, then turning black) in some never ending cycle.
Well I belive that the problem has to do with the memory vmod. I'm not saying that just doing the mod causes the problem (cause it doesn't). I belive that when you did the memory vmod, either some of the lead got somewere it shoudln't have, or you just wern't neat enough.
Now I found to fix this problem, first clean of the memory vmod area (a general area, get all around it, and especially good at the resistor it's self) with some alcohol. Then take an eraser on a pencil and clean off the reisitor gently (and a little around it too). Then redo some more alcohol to clean it off again.
After you cleaned it, you can reapply the memory vmod a little neater and you probably shouldn't have the problem anymore.
I know all this cause I did both vmod's. Then I was have a lot of artifacting (as in I did something really wrong) so I reversed both vmod's. Now the vgpu mod I could clearly see was clean, so I knew something was up with the memory vmod (cause I thought I cleaned it off enough but I really didn't ). Just be sure to clean off that memory resistor real good if you do reverse the vmod's.
Originally posted by: aldamon
Both of my $2.99 Harbour Freight multimeters came with a regular 9V battery installed. I really don't know how they make any money on them.
If people want instant gratification, HF has lots of B&Ms:
http://www.harborfreight.com/cpi/ctaf/retail_stores.taf
I got my MMs at the Raleigh store.
Originally posted by: starwars7
Great Guide! I'm a newbie and a little bit nervous about this, but you make it look so simple. After we change the Volts does it automatically increase the clock? If not, what program do we use to adjust them?
I'm also looking into after market cooling and have seen some people mention the Zalman VF900 for the Video cooler and was wondering what people though about that cooler or other coolers.
Finally, I really know nothing about additional video RAM coolers if anyone has a suggestion.
Thanks!
Originally posted by: Stoneburner
I don thave a nvidia card, but can't you just up the voltage through software?
ok, nifty that makes sense.
So what would we want to clock it to with coolbits after your mod?
I also googled for the RAM coolers and found these:
http://www.xoxide.com/swiftech-mc14-copper-bga-ramsinks.html
Is there a particular brand you recommend?
I was also wondering how many I will need?
And are they something I could use to cool other PC parts as well?
You seem pretty knowledgeable about hardware mods, do you know any good ways to cool the PWMIC on a MOBO, mine is hitting 57C at load?
Sorry about all the questions.
Originally posted by: aniruddha23
lil off direction but can someone give me before after 3DMark05 scores on the 7900GT after volt modding. anybody who has done this.
Can't help you with 3DMark05 scores, but here's some before and after 3DMArk06 scores:
Stock (450/660) : 4695
OC (532/784 ): 5411
Volt Mod OC (685/885): 6559
