So. These websites being biased because of their so-called discoveries.
Correct me if i'm wrong, these discoveries were absolute legitimate issues that were discovered and acknowledged by AMD, with CF microstuttering being a prime example. I just don't get it. These discoveries make these sites biased, but these were real, factual, and acknoledged bugs. What gives? Should users just be left in the dark? Apparently, that's what some people here want. Everyone left in the dark. Do you want to be left in the dark with other consumer products? Like an automobile with faulty brakes? The bias review site that makes mention of faulty brakes. How dare they do that. Shills. Jerks. For mentioning a product fault. Excuse me while I roll my eyes.
Come on. I can't believe i'm reading this stuff. Real issues. Get over it. That doesn't make them bias. Funnily enough, HardOCP was actually the website that gave AMD cards the hardest time with crossfire microstutter particularly with the 79xx cards. They just did not have a means to test it with FCAT, and they don't plan to do that, but they made clear mention of microstutter problems with AMD cards for years.
Were they right for doing that ? Yes. You don't leave consumers out in the dark by omitting product faults. Product faults should be front and center. Again I can't believe i'm reading that mentioning product issues are the fault of the review site and not the fault of the product. The level of persecution syndrome to get to that level is quite ridiculous. Brand doesn't even matter here. If NV had an egregious issue that affected their GPUs on a wide level which ruined immersion or experience, I WOULD want to know. I would expect sites to do that. And they have. The 590 VRM issues being a prime example, that was publicized everywhere. GTX 480 heat and noise issues. Review sites had a field-day with it, and I didn't disagree. While I do really like what NV has these days in terms of GPUs and prefer them, I was definitely not impressed by the 480 due to heat and noise issues. And review sites were incessant in slagging the 480. Should they have slagged it? Absolutely. I agreed. I feel similarly about the 290/290X reference design, and AMD was made aware of this as numerous websites made mention of the heat and noise issues. Guess what. The successor to the 290? How much do you want to bet that AMD will improve the reference design of whatever Hawaii's successor will be as a DIRECT RESULT of reactions to their 290X reference design? I'm sure it's going to happen. Product improvement due to issues being brought to their attention FRONT AND CENTER on review sites.
People need to know about these things. It isn't a brand thing. It's a consumer protection thing. It also improves subsequent product. How can anyone not see this. Fermi GTX 480 was slagged for being hot and loud. Nvidia went to the drawing board for the much improved 580, and then the very efficient Kepler and Maxwell architectures. AMD will undoubtedly improve their 290 successor in terms of reference cooling. And even on the 290, frame pacing was fixed. WHY? These product improved are MADE BECAUSE OF DISCOVERIES just like the ones mentioned here. Yet despite this, cries of bias website. Shills. What-ever. These types of reviews directly improve the products you get. These sites doing these discoveries are helping you with subsequent products being better. Not hurting you. Just stop with the persecution syndrome stuff by blaming the website for a product issue. Place the blame where it lies. Has got nothing to do with brand. Everything to do with consumer awareness and protection.
And the good news is the 290 series of GPU fixes these problems with microstutter. Would that have happened had these revelations not been discovered? Who knows. Maybe not. But no one is complaining now are they? They have a better product with smoother frametimes, that's the end result of these discoveries. Yet these sites are biased for the end result of an improved product, by making the powers to be at AMD aware of the issues.
