Originally posted by: Shivetya
funny how its called maiden flight, I guess that meets actual production models as we have both F22 and F35 overflights here in Georgia
How could there be ANY F-35 overflights in Georgia, of all places?
Consider this:
1) The X-35 DFlight Concept Demonstrator was built and assembled in Palmdale, and has flown all of it's demonstration missions
in and around the Edwards Flight Test Facility, 35 miles Northeast of Lancaster California.
2) Air Vehicle 2AA:1 is the frirst of the production prototypes, which is this particular aircraft which first flew last Friday.
It is the ONLY configuration that will be made in the CTOL prototype design of 2AA:1, since it's purpose is to refine assy
tools, techniques, and isolate vendor and supplier irregularities that will lead to changes in the subsequrent madels of design.
The next vehicle that will be made, several in a row actually, is the STVOL Short Takeoff and Landing configuration - 2BJ:1 - @BJ:3
which incorporates the Lift Fan and transfer drive mechanism that allow the vertical deflection for the takeoff and landing cycles.
Then they return to the 2AF:1 Conventional Takeoff design which incorporates the design corrections and enhancements
that were found during the fit and mating of the 2AA:1 unit, which made the 2BJ series and the subsequent 2AF series better vehicles.
Later on, as more refinements are developed, the Carier Version with larger (and Foldable) wings and controll surfaces
along with a stronger nose gear strut (Catapult Launch) and tail hook (Arresting Device) will be developed and flown
all refinements based on data accumulation from the 2AF, 2AF, and 2BJ deesigns as flight testing matures.
The engines in the JSF are almost the same as the F-22 uses, except only 1 in the F-35 design.
This is the most powerful single engine ever placed into an airplane, and it's performance will approach that of the F-22
and many of the F-22 features will be able to be phased into the functionality of the F-35 as the airframe design matures.
For those of you who think that it cannot replace the A-10, you're in for a rude awakening.
The A-10 Warthog served quite admirably, and is continuing to be fixed by band-aid to salvage the functional airframe . . .
until the much more capable F-35 variants are available to replace them.
There has been considerably less problems in the design and development of this aircraft than any other aircraft in the history of aviation.
Don't underestimate any of the capabiliities of the F-35, although it dosen't propose to replace the F-22 - it's not supposed to.
Few other aircraft in the world will be able to perform and deliver with the capabilities of this aircraft, multiple variants and all.
You guys don't have a clue as to what the armament capabilities for this weapon system will encompass.
