Originally posted by: lokiju
My brain is broken now![]()
Originally posted by: dNor
These sorts of things are obnoxious. Epic fail, brain!
http://infohost.nmt.edu/~armiller/illusion/craik.htm is even worse.
Originally posted by: NanoStuff
Originally posted by: lyssword
wow. I guess the brain looks at the whole picture instead of trying to compare small details
The brain perception of shade and color is relative, this allows it to see the 'true' appearance of the object disregarding shifts in illumination and hue.
The same is true for color. A blue but red-shifted object in a red-shifted surrounding will appear more blue than it really is. When you look at it in a neutral surrounding then you will see it's actually more red than you were led to believe. The brain in this case subtracts the common color so you can see them more naturally. This makes perfect sense for example during sunset, so that you can still clearly see green leaves as green even though the amount of green light they are giving off is minimal.
In this case you can still see white as white despite the shadow being cast over it.
The illusion makes it seem like our brains are easily deceived. In reality this makes our brains particularly hard to deceive because we can see right through such impedances to determine the real nature of the object. Had both squares looked the same, in the natural world this would actually be a flawed perception because once the shadow is removed it becomes clear they are not. Only on a static raster image you are led to believe there is something defective about this.
Originally posted by: Whoozyerdaddy
It's the contrast between the letters A and B that throw it all off...
Originally posted by: Modeps
Originally posted by: thetxstang
Sorry, I'm still in disbelief (i.e., shens). I've stood 30+ feet back from my LCD, where both the A and B letters are indiscernible, and I still see a marked difference in color. I've also stared at the squares for more than a minute head on, making myself try to see the same shade, and still I don't. I'm not a Photoshop user, but I'm still having trouble believing this.
You cant call shens on something that's proven.
I too had to confirm it with a photo editor. Crazy.Originally posted by: mrSHEiK124
Damn, I didn't believe it till I opened it in Photoshop....
I think it's because the surrounding "black" boxes become a lot darker in that area.
Originally posted by: v1001
Sorry man but I've looked over this over and over. They are very clearly different colors and shades. There is no mistaking this.
I've even physically blocked off the the surrounding squares with my hands. They are different. When I run my mouse over it it clearly is a different picture and color that they put in there for the one block to then make it look the same.
Load it into a photo editor, and copy and paste. Or, if you've got an editor with the ability to "pick" colors from an image, do that. GIMP says that both are exactly the same color.Originally posted by: v1001
