the magnets inside a hard drive are dangerously strong
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,204
45
Originally posted by: Modelworks
yep, they are very strong.
Not as strong as ones you can buy, like the 35lb variety. meaning it takes 35lbs of force to pull them apart.
If the magnet was oriented towards the platter it would wreck havoc on the data.
Instead it makes the actuator function, that moves the arm back and forth, and also serves as an auto head parking mechanism.
Fun thing to do with these I did last week.
Take a eraser, the big ones that are kind of flat.
Hollow it out enough to pllace the magnet in the bottom.
Glue it in place.
Two things you can do now.
Attach it to metal objects and watch as peopled try to pick it up.
Or my favorite.
Amaze the kids.
Place the eraser on a table top and place the other magnet below the table surface.
Use your 'mind power' to make the eraser move :)
Oh, and make sure you keep it far away from your wallet.
It can corrupt credit cards in a single pass.
35 pounds? pffft :p
http://www.unitednuclear.com/magnetfull7.jpg (800 pounds)
http://www.unitednuclear.com/magnets.htm
jagec
24,442
Originally posted by: BlahBlahYouToo
Originally posted by: Superself
can you elaborate on the "dangerously strong" remark?
given its small size, you would never expect it to have such a strong magnetic pull.
put it near any metal objects and it will pull it towards the magnet at a high rate of speed.
put the 2 magnets together (comes in 2s) and it would be a struggle to pull them apart, possibly injuring yourself in the process.
No offense, but you have to be a serious moron to get hurt by a hard drive magnet. Unless you stuck them on your balls or something...but that brings us right back to "serious moron".
Yeah, they are surprisingly strong. But not dangerously so.
Baked
36,052
17
I have a couple of them from a failed HD I took apart. Handle with caution.
Modelworks
16,240
7
oh crap, it was kinda on my thigh near my wallet when i was messing around with it.
didn't even think about it.
uhoh :)
middlehead
4,573
I hope you weren't planning to have children.
Analog
12,755
seriously, i had no idea.
if u need a strong magnet and have a dead hard drive laying around, take it apart.
Check out the massive magnet I took out of my '82 vintage 10 Megabyte (yes megabyte) Hard drive:
Text
BEAT THAT!
slag
10,473
Sure you would.. they are rare earth magnets.
This is all pretty much common knowledge to most people.
Fritzo
41,920
2,161
How to kill yourself using two of those magnets:
Step 1: Swallow one.
Step 2: Wait about 10 minutes, then swallow the second one
The two magnets will eventually attract themselves together through the walls of the small intestine, causing necrosis, and eventually death.
Get to it and post your progress!
S
SlitheryDee
Upon reading this thread I disassembled an old HD...and immediately pinched the shit out of my left index finger with the magnets inside it. Still hurts like hell. :(
Edit: Ugh It's turning purple.
Throckmorton
16,829
Are you sure they are rare earth magnets? I thought they were made by magnetizing molten steel, and then cooling it with all the molecules in the aligned position.
I discovered the other day that they are horseshoe magnets. Both the N and S are on the same side. You can feel that if you take a small, normal magnet, and move it back and forth in front of the HD magnet.
That's why the back, where they attach to the metal backing, is not magnetic.
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
Originally posted by: YOyoYOhowsDAjello
35 pounds? pffft :p
Yep, the warnings that go along with those magnets aren't to be taken too lightly. Before entering a room, make sure you've carefully planned out the route you're going to take if you're carrying one of those magnets. Don't walk near scissors or other sharp metal objects! Put one of those magnets in each hand if and only if you're bored of having fingers.
Jul 10, 2007
12,041
trying to pry the 2 magnets together. they clamp down on your fingers and pinch some skin.
you're hurt.
:roll:
Kelemvor
16,928
8
I have a few of them I took apart just to get the magnets. They are freaky strong.
Iron Woode
31,252
12,777
if you get enough of them you can be a real life Magneto.
Eeezee
9,922
If you're dumb enough to pull at something until you HURT YOURSELF then you are a moron.
There's nothing dangerous about the magnet inside a hard drive. Yes, it's strong. Hurting yourself by pulling apart two strong magnets is equivalent to hurting yourself while trying to pull apart a Victorian era dining table without tools.
Eeezee
9,922
Glue it in place.
Or my favorite.
Amaze the kids.
That last line, I believe, is a myth. It might wipe the data if they come in contact, but I don't think passing the magnet over your wallet will do anything to the credit cards (it's a strong magnet, but not that strong)
DrPizza
Mar 5, 2001
49,601
167
111
Glue it in place.
Or my favorite.
Amaze the kids.
I use fairly strong neodymium magnets in physics class. When I'm done with a demo, I have this bad habit of putting the smaller things in my pocket so I don't misplace them. I've ruined every credit and debit card I've had.
Modelworks
16,240
7
I did that to checks.
Checks in case people didn't know are now printed with magnetic ink.
External magnets can screw it up so bad that magnetic readers can't read the check, making processing time longer.
Modelworks
16,240
7
Its no myth.
Have you seen the degaussing pads that stores use to clear the security tags ?
Notice they have a warning not to place credit cards on them ?
Those are about 5 times weaker than the magnets we are talking about.
GTaudiophile
29,767
33
Any know how to uncrew the scews on a HDD. None of my tools are small enough/right type to get at them.
sdifox
99,346
17,545
why bother with the screws? not like you are going to put it back together and boot off it.
40Hands
5,042
"A small child recently lost his hand when his father left two # 31 supermagnets unattended. The child picked one up and when he approached the other magnet on a nearby table, it became airborne and obliterated his small hand."
:Q
GTaudiophile
29,767
33
You mean pry it open then?
