Fallen Kell
- Oct 9, 1999
- 6,155
- 504
- 126
Why would you run 18 for 35ft? I run 12ga everywhere. Diff in resistance between 10ft and 45ft is 0.05558Ohm. In other words, negligible.
I am not saying to run 35ft of 18ga wire. I was making the point (because a lot of people do run 18ga wire). But that doesn't change the issue. Your 12ga will have a capacitance difference a lot higher than the 18ga due to the larger distance between the centers of the hot and ground wires (due to the wire being that much thicker). Over a longer distance run, this capacitance will be higher, which will also change your crossover points as it now has a larger capacitance than intended. This is not as easy to state directly, as the insulator width used as well as the other structuring of the cable (i.e. twisted pair, etc), will change the capacitance of the wire. Resistance is a direct property of the length of wire+material used, capacitance has a lot more to do with the exact configuration of the wire as well, and thus can not easily say what the difference would be for a 10 foot run vs a 45 foot run. This is why my example of the reason for using the same length wires talked simply about the resistance, but as stated, capacitance is also very much an important part and will affect things even more so than resistance.
