The fuse blows when I have all my PC's on and someone uses the microwave
alkemyst
83,769
19
Yeah don't just change the fuse/breaker to a higher number...usually the rating there is based on the wiring ability.
Depending on your box (hehe) and were the circuits are you could run a new circuit. It's really easy if the building cooperates. You have the in wire, the breaker/fuse, the wire out, the plug/switch, and the device.
Easy....
However you may find things like 6" of concrete along your journey :)
Pepsi90919
Originally posted by: psteng19
Originally posted by: ness1469
This is God's way of saying not only do you need to get a life and stop thinking you need 5 computers running, but that you need to get your ass away from them and stop making microwave burritos while you are being a nerd.
I have friend's over my house and we're either playing LAN games or have a scrim going on.
As if you know what's going on in my life
we do now, you just spelled out its non-existance in black and white.
alkemyst
83,769
19
j00 jest got pwned! ;)
Ornery
17
I already have 4 power strips running down here.
The circuit breaker just flips off, so those power strips aren't helping.
I've run 50 ft heavy duty extension cords from upstairs when I had people bringing their PC's over. But as a permanent solution, it won't help. Too unsightly and I don't want to trip over more cords.
"...the fuse trips to prevent overload."
Is this a fuse box, or breaker box?
Actually, the kitchen appliances should have their own dedicated circuits. Is this an old, under wired house? Does it have grounded plugs? Where is the box, upstairs or downstairs? You're saying there's not a single other circuit you can use in the basement? Is there an attached garage? Could you string an extension cord from the garage, through the wall, and into the basement? Might just have to do that for now. In the end, you'll need to add to or rearrange that breaker box.
psteng19
5,953
It's a breaker box.
The house is probably 40-50 years old. The plugs are not grounded, only the face plate is (which we changed ourselves). Attached garage, but it's a split level so the garage is far away.
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
run a new outlet for the microwave. They are supposed to have a dedicated 20a breaker anyway. A microwave pulls 80% of the rating of a 15a breaker during normal operation. Of course the breaker will trip.
Beau
17,730
www.beauscott.com
"Had to get the medal plate in my head replaced with a plastic one. Whenever my wife would run the microwave I'd piss my pants and forget who I was for half an hour..."
sharkeeper
10,886
"Honey have you checked our shitter?"
Cheers!
