Originally posted by: Mark R
Originally posted by: AMCRambler
Close. Colder air is more dense and since there's more air per square inch/meter whatever, the mass airflow sensor detects this and the cars computer will increase the mount of fuel it's putting into the engine. Otherwise the car would run lean. Same reason when you put a turbo or super charger on your car you've got to increase the amount of fuel being pushed into the engine, aka fuel pump upgrade, fuel regulator change, larger injectors, etc.
This is irrelevant.
The total power produced by the engine depends on the total mass of air and fuel aspirated by the engine. Except under WOT conditions, this is limited by the throttle, which is controlled by the driver to provide appropriate power for the conditions.
Certainly in cold conditions, the engine is capable of higher total power output because it can aspirate a greater mass of air - but the proportion of time that an engine spends at WOT is so small as can be ignored.
Much more significant are changes in the total energy consumption/delivery:
a) depending on the climate, winter drag may be 10% higher than summer drag - thus 10% additional fuel would be required for the same journey
b) Fuel mix - winter fuel is more volatile (to aid starting) and contains less energy per gallon
c) In very cold weather the engine takes longer to reach operating temperature - efficiency is greatly reduced during the warm-up phase
d) Different driving conditions - idling the car to 'warm-up' the engine is a tremendous waste of fuel; lower speeds may be required in icy conditions (which may be less efficient); different tire performance (e.g. lower air pressure, change in rubber properties)
