You're arguing semantics. It is a blower cooler (like the reference is) with slightly different (wider) dimensions. IT IS designed exactly like the reference fan but slightly wider - it is pretty much exactly the same. You can't have the overclocking headroom with that junky cooler that an asus DC2T would have.
Of course, EVGA fanboys (this isn't directed at you, just saying in general) will cream their pants over any turd of a card that EVGA releases, and then EVGA will overclock it by 20mhz for you at a cost of 30$. 30$ for a superclocked card, good stuff there. Meanwhile for that same 30$ gigabyte asus or MSI will give you a real cooler that gives you actual OC headroom and better quality. As far as customer service, you'll probably need it considering EVGA had so many defective 670 cards.
FTW model, the RAM is overclocked, so is the GPU. It has the 680 reference cooler with the high flow bracket and is $409 AR. High flow bracket costs $10 not including shipping. I don't see an issue with the price.
Core Clock:
1006MHz
Boost Clock:
1084MHz
Effective Memory Clock:
6208MHz
Vanilla clocks are 915/980 on the GPU, 6003 on the memory, a little more than 20mhz. I am not an EVGA fanboy... I did get flamed on here for expressing my bad experiences with their customer support though so there is your unbiased answer.
