The 480: power consumption, PCI-E powerdraw
Yakk
1,574
275
Looks like AMD issued a statement and will be issuing a driver fix :
As you know, we continuously tune our GPUs in order to maximize their performance within their given power envelopes and the speed of the memory interface, which in this case is an unprecedented 8Gbps for GDDR5. Recently, we identified select scenarios where the tuning of some RX 480 boards was not optimal. Fortunately, we can adjust the GPU’s tuning via software in order to resolve this issue. We are already testing a driver that implements a fix, and we will provide an update to the community on our progress on Tuesday (July 5, 2016).
Much ado about nothing IMHO.
desura
4,627
129
101
I read a pcworld preview/review saying that it was cleaning up. Made me regret selling the stock.
Not so regretful now.
Abwx
11,937
4,910
Nice article with some technical infos :
The VRM power delivery circuitry on the reference RX 480 printed circuit board is beyond impressive. More so when compared to the GTX 1080’s 5+1 power phase design which simply pales in comparison. The RX 480’s on-board VRM – voltage regulator – on the high-side is capable of delivering 40 amps from each phase at 125c, for a total of 240 amperes.
At room temperature each phase can deliver 66 amps for a total of 396 amps on the high-side and up to 600 amps on the low-side. The GTX 1080 Founder’s Edition voltage regulator can deliver 30 amps at 125c from each of its five phases, for a total of 150 amps on the low side, 246 amps less than the RX 480. At room temperature it goes up to 50 amps per phase for at total of 250 amps, 350 amps less than what the RX 480 VRMs can deliver at the same temperature on the low side.
rgallant
1,361
11
Will AMD/AIBs take some responsability here?
if amd made that board
3 cards = 3 pci-e slots with no aux 12v plug for the slots I guess.
cheap board not design to run 3 cards at max. 24/7
3 x gtx580's would have burnt the same board imo
should have added I never look at a mb that does not have a aux. 12v connector as I run sli always
also that peep has been mining on that board with other 3 cards mining for how many hours before the RX 480's
torlen11cc
143
950 (no power connector) uses more than 75W:
Azix
1,438
67
not likely. there have been tons of pictures like that before rx 480. Even with single slot cards. Just because it happened with the rx 480 does not mean its responsible.
I wonder though, because recently we saw that a few cards do actually have much higher spikes on the pci-e slot. Would those fry the motherboard more frequently if you put 3 of them in the system? Seems they should. That's a massive load if the spikes line up. That is probably why miners use powered risers.
Shivansps
3,918
1,570
The thing is, you need to generate HEAT to cause problems, peaks are not gona cause that, its the constant current draw that gona cause connectors and pins to heat up and burn, 1ms peaks are not just not enoght.
Peaks may blow up components, but i dont think there is much to blow up there, also im petty sure MB traces and components can handle the peaks, the connectors, mainly the ATX one, are the weak points, and even then a single RX480 its unlikely to cause damage, at least at stock, CF, and specially overcloked CF, may do.
freeskier93
487
19
At least in civil engineering the connector is overspeced compared to the line and breakers.
I think in electronics it is exactly the same.
Anyway. I'm curious if they can change the VRM controller load balancing with software.
There is no cost associated with trace size, so unless the board is super space constrained you'll probably find that the traces are oversized if they are delivering power. Or you might find the connector/component is directly connected to a power plane.
Azix
1,438
67
frequent peaks will. Frequent spikes on multiple slots especially.
but I think this is more than rx 480s. Combination of motherboard used and/or number of cards and 24 pin connector being loose, and/or the power supply being rated for less amps than was needed on the 24pin.
The last bit might be the reason because its often the actual plug from the PSU that burns. 3 x 75W exceeds what some of these plugs are rated for. Even within spec you are asking for trouble since there are only 2 * 12V contacts on those 24 pin connectors. rated from 6A to 13A if you are lucky. Worst case they are 144W contacts.
https://bitcointalk.org/index.php?topic=62686.msg733782#msg733782
http://www.tomshardware.co.uk/power-supply-specifications-atx-reference,review-32338-8.html
JDG1980
1,663
570
They will lower the clocks or voltage and their is no other logically way.
It's quite plausible that the fix will simply amount to an undervolt. There have been several reports of people reducing power consumption and increasing the percentage of time the card stays at full boost clock by reducing the voltage states in Radeon WattMan. Has anyone tried this and failed? I'd be interested to hear if there are RX 480 cards that crash when modestly undervolted.
It's possible - indeed likely, given that it was standard operating procedure during the 28nm era - that AMD is giving these chips quite a bit more voltage than they need. I thought the new power management features of Polaris were supposed to eliminate the need for factory overvolting, but either they somehow weren't enabled in the existing configurations or aren't effective.
MrTeal
3,919
2,708
High spikes are fine, and keep in mind that some of these spikes can be measurement artifacts.
While I've obviously not looked at every card in existence, I would posit that most high power cards are generally fine, as high power ones (even 290X, GTX580 and the like) draw almost all their power though their power plugs and draw fairly minimal current through the slot even when overclocked. For awhile I had my two 390s hooked up in my system with my dual 390 Devil 13, and even though my MB doesn't have a supplementary power plug and the system was drawing 1400W at the wall there wasn't issues because of that.
It's counter intuitively the low power cards that would be a problem, since they're trying to pull 150W through the slot and a 6 pin or 75W through the slot. It just doesn't cause issues much since no one in their right mind runs 750Ti quad-SLI.
Abwx
11,937
4,910
Don't these micro-spikes get filtered out by capacitors anyway?
No, the capacitor are indeed a cause for those spikes since charging them after they got discharged a little by an abrupt current rush is what cause thoses peaks more than the GPU itself, at those points the PC PSU must supply both the demanding GPU while charging the capacitors..
Doom2pro
587
619
Umm NO... Capacitors are used to filter voltage ripple, they are used as "bypass" capacitors for this reason and it is why you see lots of capacitors around ICs as they are sensitive to voltage ripple and need a locally stable supply as other ICs around them will cause voltage ripple on the same rail.
You are referring to inrush current, which is when large capacitors on power rails are charged on device turn on... That is totally different.
Doom2pro
587
619
A capacitor's ability to smooth voltage ripple is dependent on it's Capacitance in Farads and it's Equivalent Series Resistance (ESR).
The lower the ESR and the higher the Capacitance the more it's able to smooth out voltage ripple on a supply rail.
In short, it depends on the voltage ripple, if it's too high the capacitors can only do so much.
Abwx
11,937
4,910
That doesnt work like this, the capacitors that are in the PC PSU are the one providing the necessary current peaks to charge (while supplying the GPU) the capacitors of the card that are slightly discharged by a sudden demand of the GPU.
We are talking of current peaks while you are thinking instantaneous voltage variation, you could have huge current peaks without the voltage moving much if the PSU and routings have low impedances.
Doom2pro
587
619
We are talking of current peaks while you are thinking instantaneous voltage variation of the voltage, you could have huge current peaks without the voltage moving much if the PSU and routings have low impedances.
I'm not talking about the capacitors in the PSU, I'm talking about the capacitors on the circuit boards, the SMD and Solid Capacitors around ICs and the like... They are bypass capacitors and they smooth the voltage ripple on the rails that power the ICs, the ripple being caused by other ICs on the same rail, NOT the ripple caused by the Switchmode Power supply in the PSU.
The poster you replied to was asking if the capacitors smooth the ripple caused by ICs drawing too much power, and they (the bypass capacitors) do filter this ripple (to a limit).
The capacitors in the PSU are used to smooth the ripple from the high frequency DC coming from the secondary side of the transformer + rectifier. They only provide a baseline smooth DC supply for everything else (usually it's like 120mV max ripple for 12V and 50mV max for 5V and 3.3V).
However, local rails on the motherboard and on add on cards have sources of ripple from the ICs on those boards/cards and they need local bypass capacitors to smooth this additional ripple.
The RX 480 drawing excessive current from the local PCI-E power rails on the motherboard will cause excessive ripple on that rail as a consequence, but the standard maximum power limit has been derated anyway as any good design does, so it should be safe regardless (as long as you are not OCing or using > 3 cards at once).
MrTeal
3,919
2,708
It would actually be nice if Tom's posted the current data rather than the power data. Power data (without using a proper power meter) is prone to error caused by any phase shift in the instrument itself, as well as time delays in the sequencing of readings on their DAQ. Really all that matters in this case is the current anyway; 1A per pin on the 3.3V rail is just as stressful on the connector as 1A on the 12V rail.
May 11, 2008
22,881
1,490
When i read it, it seems they have the data sheets of the high side and low side mosfets. I wonder if they have the inductor datasheets as well. Because that is a lot of saturation current that the inductors need to handle for such a relatively small size.
Abwx
11,937
4,910
I'm not talking about the capacitors in the PSU, I'm talking about the capacitors on the board, the SMD and Solid Capacitors around ICs and the like... They are bypass capacitors and they smooth the voltage ripple on the rails that power the ICs, the ripple being caused by other ICs on the same rail, NOT the ripple caused by the Switchmode Power supply in the PSU.
I already answered, you are talking of voltage ripples, that they are created by current variations is right but they are not an indication of the PSU varying current absolute values.
Without those capacitors peaks would be much lower and voltage would sag, they provide the low impedance at high fequencies (short peaks)..
MrTeal
3,919
2,708
The RX 480 drawing excessive current from the local PCI-E power rails on the motherboard will cause excessive ripple on that rail as a consequence, but the standard max has been derated anyway as any good design does, so it should be safe regardless (as long as you are not OCing or using > 3 cards at once).
Well, in this case you're actually more interested in the input capacitors than the output capacitors of the VRM. They're they ones that really help suppress input ripple, along with an input inductor if the designer chose to include one.The input capacitors aren't as sexy spec-wise and they often don't get the attention they deserve in VRM design, but they have a massive impact on input ringing and stability. Often the layout of the input capacitor plays second fiddle to optimizing the output; sometimes to the detriment of overall noise. Josh Mandlecorn from TI wrote an interesting app note on the effects of input capacitance positioning and sizing and its effect on input current ripple; I should see if I can dig it up.
May 11, 2008
22,881
1,490
What is also the issue, is that these are smps. Switching power supplies. That means they radiate a lot emi. What MrTeal means is that your oscilloscope probe can also pick these emi signals up and make them look larger than they really are. Even professional measurement tools can fall victim to this.
An easy and cheap way to measure the voltage on smps power supplies is to use a twisted cable with a small capacitor to filter the really hf and connect that to the signal you want to measure to an oscilloscope probe, far away from the smps. It really works. the emi cancels out more or less because of the twisted cable.
Abwx
11,937
4,910
They will just cost a little more by a few cts for the whole...
Anyway seems that some people give more importance to a few watts extra on a PCIe connector than to the design of a card PSU considering that there will be much more failures for overclocking a 1080 due to its weak PSU than with a few dabolized watts through a PCIe...
Basicaly the 1080 has a sub 200W PSU in worse conditions, but this is not a problem apparently...
Doom2pro
587
619
Without those capacitors peaks would be much lower and voltage would sag, they povide the low impedance at high fequencies (short peaks)..
Without those capacitors, the ICs would be VERY unhappy... You are doing the chicken and the egg dance here... Capacitors cannot cause current (or power) spikes (after being charged of course) without something loading them down, the thing loading them down is the IC (GPU Die+RAM).
Why are you focusing so much on the capacitors themselves? The source of the current (and power) spikes is the GPU itself drawing down the rail to which the capacitors can only sustain voltage for so long.
