Tft monitor and quake 3 engine games
choiz
Im using a TFT monitor to play Quake 3
Id like to play at 1024x768 at 75 hz
Do I need to use
seta r_displayrefresh 75 to force 75 hz
With the above settings can I use
seta com_maxfps 125
or should I stick with
seta com_maxfps 75 or try for 77
vsync on or off ?
Finally would Q3 be better at the native res for my monitor
1280x1024 75hz
My eyesight aint good
Will higher or lower res be better for me
Digimate 17 inch monitor
Panel Size: 17''TFT (Active Matrix)
Resolution: 1280 x 1024(SXGA)
Pixel Pitch: 0.264 x 0.264mm
Display Colours: 16.7M
Brightness: 260cd/m2
Contrast Ratio: 450:1
Scan Frequency: H:30-79KHz V:50-75Hz
Response time: 16ms
Viewing Angle (H/V): 140 degree(H)/ 140degree(V)
OSD language: English, German, French, Italian, Portuguese, Spanish, Dutch
Input Signal: VGA (D-sub 15pin)
Internal Speaker: Built-in stereo speakers. Stereo Phone Jack(L/R)
Optional: Video in: DVI-D, RCA
Power Supply: Input DC 12V 4.16A
Power Consumption: MAX 48W, Standby 3W
Net weight: 4.0 kg
Carton Dimension(W x H x D mm): 445 x 419 x 153 mm
Monitor Dimension(W x H x D mm): 378 x 386 x 53.5mm
Regulation Safety&EMI: FCC, CE, VCCI, BSMI, UL/CUL
My rig
Asus A8N-SLi nForce4 SLi (Socket 939
AMD Athlon 64 3500+ Winchester 90nm
Corsair 1GB DDR XMS3200C2PT TwinX (2x512MB) CAS2
Gigabyte GeForce 6800 GT 256MB DDR3 PCI-Express
Enermax Noisetaker 600W Sli Compliant
Seagate Barracuda 7200.8 Plus NCQ 250GB
Coolermaster Centurion 5
Pioneer DVR-109 16 x 16 DVD±RW Dual Layer ReWriter
Creative Sound Blaster Audigy 2 ZS 7.1
Arctic Cooling Rev.2 nVidia 5 (6800 Series) VGA Silencer
Winxp pro
71.89 video drivers
thx
best to turn off vsync, as that never helps. Also for that monitor, try simply running it at 60 hz. if you attempt to force refresh to 75, it will start flickering. I'm not sure why, but thats just how it is even though it's counterintuitive.
