igor_kavinski
- Jul 27, 2020
- 24,043
- 16,800
- 146
That's based on bad experience and lack of knowledge. Buy Micron, WD or Intel used SSD, check their life remaining counter in CrystalDiskInfo and that's it. You should be good until the writes get exhausted. It's not unusual to even now get 1TB Intel enterprise SSDs for dirt cheap prices on eBay that will have more than 90% life remaining. Intel used to test their SSDs in a frickin' particle accelerator for reliability. You just have to know what you are buying. Intel Sandforce controller based SSDs, for example, are more likely to fail because that controller was buggy as heck. I myself had a Corsair Sandforce SSD stop working. Left it on after a year or two connected to my PC and next reboot, I saw the drives appear in Windows Explorer with all data intact (though it was old data so I didn't verify 100% integrity. Winrar archives tested OK with no CRC32 errors).My experience with SSDs is that if it's used, it's probably already good as dead. They are more volatile and self-obsolescent. Heavy use or lack of use results in the same: useless SSD even if they power on.
Buy cheap low quality brand SSD and you will get what you pay for. Next time you are looking to buy some cheap SSD, ask the seller to share CrystalDiskInfo screenshots and then you can post here to ask advice on whether you should buy it.
