toyota
- Apr 15, 2001
- 12,957
- 1
- 0
well the overall graphics in Crysis 3 make Crysis 2 look like a joke.Any one know why Crysis 3 was such a let down, when it comes to tessellation? Especially compared to Crysis 2.
360 can do tessellation but AFAIK the only game that used it was Viva Piñata.The old consoles didn't have the hardware to do tesselation so I expect this to change once primary development shifts to ps4 and xbone
This is why Crysis's implementation of tessellation is not, in fact, a good thing. As an amateur modeler, I screamed in horror upon seeing that ... solid polygon blob thing up there in the images.
And of course, the lovely "simulated water" -- under dry land with absolutely no water showing:
There is tessellation (as in Unigene, though that's subjective as well), and then there's tessellation that adds absolutely no detail (note said concrete slab is still pretty poorly textured, and has pretty poor AF on top of that) while chomping through graphical power...
Halo Wars used it for terrain vector displacement as well. (Displacement in X, Y and Z axis and thus superior to standard displacement.)It's tessellation engine has to be used much earlier in the pipeline and is much less flexible IIRC.
Halo 3 used it for water I recall.
http://www.gdcvault.com/play/1277/HALO-WARS-The-Terrain-of
IMHO.
DX11 based tesselation has it's place, but in many cases properly used and optimized meshes with proper LoDs or dynamic LoD system might be better in both quality and speed.
Who said it was a letdown? Crysis 3 uses tessellation extensively as far as I can tell.
There is tessellation on practically all the vegetation, on the characters (Psycho for instance), and on the water surface when very high is enabled.
Comparison shots:
Tessellation off
Tessellation on
The effect is most clearly seen on Psycho, and on the trees in the background.
Honestly, Crysis 3 is as close to a next gen game as we have right now. The only thing I find disappointing about it is the linearity of the levels (which can't be helped due to the setting I suppose) and the physics.
The physics is especially disappointing, because I learned a few days ago that Crysis 3 uses a lot of canned animations, even for basic physics like tree destruction. Also the cloth and vegetable simulation was also disappointing, compared to what we saw in the tech demo (check 2:25) Although the tall grass looks great I admit.
This game should have used either Havok or PhysX....preferably the latter :biggrin:
If the point of those screenshots was to demonstrate advanced tessellation...it really doesn't. All I see is some basic character model tessellation, which games have been doing for some time now (like Deus Ex: Human Revolution). It's nice, but I don't see it used to the extent of Crysis 2. But the argument can be made that the environment tessellation was overdone and ultimately unnecessary for what it added to the game's visuals.
And no thank you, I'll pass on the PhysX. Even if I had an Nvidia GPU I'd want a better performing alternative.
The point of the screenshots was to show that tessellation is being used in Crysis 3, in more diverse ways than it was in Crysis 2. I don't believe Crysis 2 used tessellation for characters, but only for various inorganic surfaces..
And Crysis 3 does use a lot of advanced tessellation, but the screenshots I posted admittedly don't show that. If you play the game, you'll notice that the foliage and vegetation in particular is tessellated. This is the first game to use tessellation on foliage I believe.
What performs better than PhysX? The latest PhysX SDK is one of the highest performing physics APIs on the market and at least it gives you the option of running it on the GPU, which Havok doesn't.
