Terrible Performance with Nvidia GT240 1GB DDR5 :(
gtd2000
2,731
Well I managed to get the updated driver installed by doing a "manual" update rather than the nVidia supplied auto-update.
This has revealed another problem (although a quick game of L4D2 was actually not too bad). In the 2D situation such as scrolling down this thread the moving portion of the screen flickers - when stationary all is fine.
This seems like ATI drivers 8~10 years ago....any ideas?
cusideabelincoln
3,275
46
Check and report the clockspeeds (memory, core, and shader) of the card. I'd recommend using MSI Afterburner. It will monitor you clockspeeds continuously, so you can see how it performs in 2D and 3D over a time graph.
Also you might have some bad Windows files. I recommend running chkdisk. Go to My Computer -> Right click on C: drive -> Properties -> Tools -> Error checking. Schedule a check and then restart. It will probably take an hour or two.
gtd2000
2,731
Hmm cancel that screen flicker problem - it's only happening on this site for soem reason...???
happy medium
14,387
480
mabe he needs to defrag his drive? :) hehehe. j/k
gtd2000
2,731
Core Clock = 550Mhz
Memory Clock = 1700Mhz
Shader Clock = 1340
I'll run the error checking overnight then.
gtd2000
2,731
Well I just created a server match with 20 players in CS:S and it's basically unplayable - framerates are way too slow and you can't aim at anything as a result - woeful!
cusideabelincoln
3,275
46
Well I just created a server match with 20 players in CS:S and it's basically unplayable - framerates are way to slow and you can't aim at anything as a result - woeful!
Bots eat CPU cycles and your CPU is already having a hard enough time with the game. Join an online match and then see if it performs any better.
Your clocks look on target. How are your temps?
Op its the drivers . I said it again. and I was right, LFD2 playing better, thank you.
mabe he needs to defrag his drive? hehehe. j/k
You are truly hilarious. I'm rolling. You are so clueless. You so desperately want to be right! And why? You think that makes me wrong? It doesn't, because you don't even understand the points I was making! Ahahahahaha.
gtd2000
2,731
SO it was better with the 9600gt?
Not wonderful with the 9600GT but somewhat better - I'l reinstall it tomorrow and see if it helps at all.
I should probably use some sort of benchmarking tool I suppose - any suggestions? I'm totally out of the loop these days...
gtd2000
2,731
By the way, after a re-boot no sign of the screen flickering on this website....
MustangSVT
11,554
12
it could be that gt240 is defective.
I think your CPU is fine and GPU is fine, at least to be in somewhat playable state(CSS is an oold game which should run fine with ur setup). but from the description, it seems to be a software problem.
I had similar problem long time ago with an agp card with wrong chipset driver but not sure if thats the case with your mobo.
If possible update chipset driver as well.
taltamir
13,576
9600GT=GT240. You should have asks us before you bought it. :(
You running a Athlon 3500? If so thats your problem.
A faster video card probrobly will not help.
DId you install the latest drivers for the gt240 on the Nvidia website?
http://www.nvidia.com/object/win7-winvista-32bit-260.99-whql-driver.html
you linked the correct drivers, but it is missing install instructions:
1. press agree and continue.
2. select "custom install" and press next
3. Check the box that says "clean install" and press next
4. agree to everything and restart the PC the when done.
Also, I agree with those who say that you really need to upgrade other aspects of your system.
Bryf50
1,429
51
Theres gotta be something up. Back in the day I played cs:s on lowest settings with a 2ghz p4, 512mbs of ram, and an fx5200(yea). Maybe its changed since then but i don't think so. In fact my next computer with and A64 3200+, 1gb of ram, and 6600gt ran it at full settings without breaking a sweat.
timma
170
i think the problem is 939's single core don't have performance for GT 240.
Skurge
5,195
and the CSS from back in the day is not the same as the one today. The engine is now very multithreaded.
nemesismk2
4,810
www.ultimatehardware.net
9600gt pretty much equals gt240 but main prob is the AMD Athlon 64 3500. I used to have one and although they are good processors if you get a Dual Core (I bought a Athlon64 X2) processor your games will perform better. For an example of the performance gain you will get:-
http://www.ultimatehardware.net/304.htm
This review features Athlon64 3500 and Athlon64 X2 4200.
Zap
22,377
7
This.
It is like saying "But WoW used to run just fine on my Intel IGP five years ago, now it is a slideshow on the same rig." That's because the game changed.
gtd2000
2,731
Well I just downloaded and ran 3DMark06 and got the following result:
4995 3DMarks
Graphics CardNVIDIA GeForce GT 240
# of cards1
SLI / CrossFireOff
Memory0 MB
Core clock0 MHz
Memory clock0 MHz
Driver nameNVIDIA GeForce GT 240
Driver version8.17.12.6099
Driver statusFM Approved
GeneralOperating system32-bit Microsoft Windows Vista (6.0.6002)
MotherboardAcer EM61SM/EM61PM
Hard drive model
Memory1536 MB
Module 1512 MB Nanya Technology DDR2 @ 333 MHz
Module 21024 MB Micron Technology DDR2 @ 333 MHz
Detailed scores3DMark Score4995.0 3DMarks
SM2.0 Score 2288.0
HDR/SM3.0 Score 3012.0
CPU Score 834.0
Game Score N/A
GT1 - Return To Proxycon 18.91 FPS
GT2 - Firefly Forest 19.22 FPS
CPU1 - Red Valley 0.26 FPS
CPU2 - Red Valley 0.42 FPS
HDR1 - Canyon Flight 33.46 FPS
HDR2 - Deep Freeze 26.78 FPS
Fill Rate - Single-Texturing N/A
Fill Rate - Multi-Texturing N/A
Pixel Shader N/A
Vertex Shader - Simple N/A
Vertex Shader - Complex N/A
Shader Particles (SM3.0) N/A
Perlin Noise (SM3.0) N/A
8 Triangles N/A
32 Triangles N/A
128 Triangles N/A
512 Triangles N/A
2048 Triangles N/A
32768 Triangles N/A SettingsDefault settings used Yes
Width 1280
Height 1024
Anti-AliasingNone
Texture Filtering Optimal
VS Profile3_0
PS Profile3_0
Force full precisionNo
Disable HW shadow mappingNo
Disable post-processingNo
Force software vertex shaderNo
Color mipmapsNo
Force software FP filteringNo
Repeat testsOff
Fixed framerateOff
cusideabelincoln
3,275
46
Your processor is going to hold back 3DMark06 scores, but even so what you posted seems a bit low. With a decent processor you should be getting a total score of around 9000. So we can't really judge what your score means since your system is different than other systems with similar video cards.
Also... it looks like the board is socket AM2. A CPU upgrade would make sense for you. The board probably only supports Windsor cores and maybe some Brisbanes.
edplayer
2,186
Let us know when you do this.
Like was already posted, the 9600GT is slightly faster but you should see them as almost the same in-game.
exar333
8,518
8
Four issues here:
-Slow CPU
-Not enough memory
-The new GPU is the same speed as the old GPU
-GPU Driver issues (potential issue)
edplayer
2,186
You need the latest drivers for Anandtech. Probably a quad core cpu. Are you using Pupkin ram? Those are the best
taltamir
13,576
Four issues here:
-Slow CPU
-Not enough memory
Potentially even five issues... one of the people here reported that the specific game the OP is testing with has issues.
