Tents
thomsbrain
18,148
i've never seen anyone's tent get messed up from sunlight damage. :confused: just use a tarp to protect the bottom from getting torn up and you're good to go. so save your back and get a non-canvas model. i have an REI 3-man that I got as a hand-me-down from my parents. it's probably 15-20 years old and is still in great shape.
psiu
1,629
If I remember right you can rent tents from REI. That might be a good way to check them (tents & REI) out and get an idea for what you want and need.
acemcmac
13,712
Originally posted by: imtim83
The Eureka Timberline looks nice but it seems to good to be true for it to be only $100 it seems? Is it a high quality tent? I am asking because I didn't think you could get one for $100. Does it handle snow ? Its only a 3 season tent I see. I do know that Eureka makes good tents though but just curious why go with Eureka instead rather than Northface, etc ?
I've carried a Eureka Timberline 10 miles over the Apalachian trail through 6 inches of snow and slept in it, completley dry. That tent will be as hard core as you are. I dont know what you're expecting a "year round" tent to be as opposed to a "3 season" tent. Tents hold in warm air in cold weather and stop the wind and rain. That's it. I repeat. It's as official of a tent for the Boyscouts of America as there ever was and I gaurentee that they've put it through more hardcore nonsense than you could in several lifetimes. I have slept in hundreds, some as old as 25 years. They come in 2 man and 4 man models... even though I consider the 4 man to be 2+gear. You can spend more on a tent with the same capacity, but I'd consider it to be a major waste. You sure won't get any better durability. You might loose weight or get a more stylish tent, but you simply can't beat the timberline
so.... yeah, used it in snow... hurricanes.... atop blufs adjoining the chesapeake bay during wintertime with negative windchills.... I'd swear on that tent any day of the week :beer:
It rolls up into a 3-4 foot cylindircal bag with a diameter of about 6 inches and weighs approximatley 20 pounds (I'd guess)
UV damage is overrated. If you put that many miles on your tent, you'll be buying a new one for different reasons by the time you get to that point.
WyteWatt
Banned
Jun 8, 2001
6,255
How long should this tent last? Can it handle snow?
acemcmac
13,712
Think its only at the local stores though :( I don't have any near me.
no chain sportingood stores?
Sports Authority, I Goldberg, Dick's sporting goods.... hell even target and wallmart should carry tents... I'll bet at least one of them has this model
Babbles
8,253
14
Another vote for REI and Campmor, can't go wrong with them.
Back when I was a kid in scouts often enough I would just sleep in a hammock or right on the ground with a groundcloth and a sleeping bag. When I did Philmont, I can't remember what tents we carried but they weren't bad quality, just pretty bulky and heavy as hell - moreso when lugging around one around for ~60 miles.
acemcmac
13,712
"handle snow" is relative. If you set up camp before snowfall, you shouldn't have too much trouble if it snows because it won't get warm enough in your tent from your body heat to melt the snow up against its sides. as long as you have a ground cloth and the top the cloth is tucked under so that rainwater can go UNDER the cloth and not OVER it, you'll be fine. I try to avoid setting up tents ON snow as much as possible though because no matter how good your sleeping bag is, you will radiate heat and melt what's under you.... the severity of the ensuing complications can vary.
You're 1000x times better splurging on a North Face everest class sleeping bag or something than splurging on the tent... lemme see if I can find a link to my bag. Don't forget egg crate, ot at least a roll of 1/8th inch or quarter inch foam. That's critical for cold weather camping as insulation.
acemcmac
13,712
Campmor definitley, but I think REI is overpriced.
WyteWatt
Banned
Jun 8, 2001
6,255
I believe we may have a Sports Authority but none of the tents are set up. There is a store here that has them set up but they only sell single person tents.
acemcmac
13,712
I have biked with my timberline.... I have a really big jansport, external frame backpack and I tie the tent to the bottom, sleeping bag to the tent, the foam pad and the platypus up top, and secure it all down with vertical bungees.... but then again, I usually carry a 70lb pack....
You might really benefit from gettting a saddle rack for your bike
WyteWatt
Banned
Jun 8, 2001
6,255
Ok.
To bad they don't have tents you could put up in a tree. I know thats not possible though. Ir would be way to heavy and rip way to easily. Though it would get it away from a lot of the snow.
acemcmac
13,712
Ok.
I sometimes bike in the snow to get to work... but only because it's about as safe as driving the mustang.... why the hell would you be doing recreational biking in the snow???
WyteWatt
Banned
Jun 8, 2001
6,255
Do you find it hard ridding with a 70 lb pack ?
WyteWatt
Banned
Jun 8, 2001
6,255
Ok.
I like snow.
FoBoT
63,084
15
fobot.com
be sure to practice pitching your tent at home before you go out camping, the last thing you want is to get out in the wild and not be able to properly pitch a tent
WyteWatt
Banned
Jun 8, 2001
6,255
Where do you get a bike saddle rack ?
LaBang
1,571
Honestly, You seem to know nothing about bike touring. I suggest finding a place with experts on the topic and asking questions there instead of asking a bunch of people in a computer forum.
BTW, tents can and do degrade from UV radiation. For the vast majority of people this will never happen. But if you leave a tent set up 24/7 for a whole summer in a northern latitude it will only last one season
WyteWatt
Banned
Jun 8, 2001
6,255
Thats if the tent is not in the shade or it doesn't have a rainfly covering it to protect it right or no ?
LaBang
1,571
Yes, no shade. With the rainfly on though. Rainflys are more UV resistant than tents (especially on new tents). Seriously, don't worry about this unless you're basecamping on Everest for three months. Then if you are, it's easy to just cover your tent with a tarp.
WyteWatt
Banned
Jun 8, 2001
6,255
Ok thanks. I don't know how some people can chose what tent, sleeping bag, etc to get when bike touring or campiing. There so many choses its hard to know whats the best or top best to pick at times. Like one minute you may lean one way with a certain tent but then lean another way with anothet tent. I guess its just best to flip and coin and buy the tent, etc.
acemcmac
13,712
Well put on both counts. It had never occured to me that anyone would ever leave one of these tents setup for more than a week.... I've never left one stay up for more than 48 hours.
