Tenants heating system wonky = should I offer to pay their gas bill?
Mar 15, 2003
12,668
103
My tenant's heating system has been wonky for the past 3 weeks, though I've been making what I feel is adequate repairs (4 techs came and fixed various things, but the problem persists). Tonight another HVAC pro will hopefully get the issue resolved, but should I feel guilty about the month of inadequate heat, and offer to pay their December gas bill?
I'm a first time landlord so I want to do the right thing, but don't exactly have a spare $xxx dollars (though I'll eat ramen noodles for a while if that's the right thing to be done).
*Update*
The heating system was fixed last night (actually, one more piece needs to replaced, but that will be done today). I emailed my tenant earlier that day offering to take $100 off of next month's rent. She thanked me and, honestly, it made telling her that there would be no heat at all last night easier. She understood that we were doing everything that we had to do, instead of bitching. Thanks for the suggestion!
olds
50,128
781
If you addressed it immediately and they have no out of pocket expenses, I wouldn't.
meltdown75
37,548
7
you're already got 99% of landlords beat by getting right on fixing it... i'd say hold off on the ramen noodles for now.
if they complained i'd pay 1/2
14,061
What you could do is offer to lend them a high powered electric heater so they can at least have constant heat while it gets fixed properly. Sounds like you are doing everything you can though. From stories I hear most landlords would not even have bothered calling anybody.
lxskllr
60,867
11,213
How inadequate was the heat, and what state are you in? If they spent cold days in the apartment, paying a month of gas would be the cool thing to do. It may not be explicitly necessary, but it would generate good will, and will give you better tenants in the long term.
Mar 15, 2003
12,668
103
Fair enough, my concern is that the boiler has been cranking (i.e. they're paying for gas) but the heat wasn't distributed properly, so they spent money on heat that they didn't get. I'm probably just over thinking...
Mar 15, 2003
12,668
103
The heat is working but trickling - I'd say an average of 50-60 degrees inside (during 30-50 degree weather). They supplemented it with an electric heater, which I'm embarrassed by frankly, because they have the right to be warm where they live.
I would have offered them electric heaters as a stop-gap measure but they bought them before letting me know of the issue.
olds
50,128
781
That's a little different.
Maybe offer them $X off next months rent?
My dad had rentals and he used to not charge for Decembers rent if the tenants paid on time the other 11 months.
olds
50,128
781
How come when people ask for opinions it always takes 56 posts to get all the relevant info out of them?
:confused;
iRONic
8,547
3,837
Way old school. Props for yer Pops!
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
Hmmm...
My tenants had that problem for about 2 weeks. First I worked on the furnace & got it running again, but the problem occurred again. Then, I installed a ventless natural gas heater as supplemental heat downstairs. (A couple hundred, including the black pipe - and from now on, I'll only use gastite.) When the furnace went a 3rd time & the supplemental heat wasn't sufficient due to colder than normal temperatures in the spring, I went out and purchased a brand new furnace for the house & installed it. ($700ish) Ultimately, that new furnace cut their gas bills significantly & more than made up for any inconvenience they experienced. If anything, I should have raised the rent slightly because of the new furnace. Never once did I consider they deserved a break on their rent as a result - I was right on top of the problem as soon as it occurred. It's no different than what a homeowner goes through when something like that happens - the bank doesn't say "hey, we'll cut you a break on the mortgage because your heat was out for a couple days."
And, as far as 50-60... I know several people who keep their home temperature at 60 degrees or less during the winter.
Rubycon
Madame President
Aug 10, 2005
17,768
485
Good gravy on a hill of beans! Is it really that difficult to find a GOOD "heat duck man"? :D
Mar 15, 2003
12,668
103
:confused;
because i'm exhausted from being stuck in airports and coming home to both heating issues and "shouldn't have left my cats home alone because they'll fuck shit up" issues and.. and I gotta crank out this web dev assessment for work so I haven't had lunch or slept and .. life, basically leading to brain farts :)
but your suggestion was appreciated!
thepd7
9,423
Hmmm...
True, but at the very least the tenants are out the money they spent on the electric heaters. OP should reimburse for that expense or just cut them a break on rent because of it. I always err on the side of spending a little more to keep the relationship incredible because you never know what you might ask for in the future. You might want a letter of recommendation from them to any future residents or to be able to show the place with little notice and have them keep it clean. Spending a little money now could make your life a lot easier in the long run.
DrPizza
Mar 5, 2001
49,601
167
111
If they didn't get it, where did it go? That post really doesn't make a lot of sense. "Not distributed properly" is going to mean some rooms are too warm while others are too cool, not that all of the rooms are too cool.
Mar 15, 2003
12,668
103
Their bedroom (2nd floor of a duplex) was warm but the living area was colder.. Not freezing, but not warm...I've heard mixed reasons and honestly don't know shit about the HVAC world, It could be, as said by one tech, a blockage in the lines in the living room.. One tech thought it was the thermostat and replaced it.. Another just bled the boiler.. I have no idea about any of this, my question is more about ethics than anything.
