SpatiallyAware
- Sep 7, 2009
- 12,960
- 3
- 0
frankly at that point the Fuel cost should be the LEAST of your worries. i would be more worried about the inside of the house, the plumbing etc.
In the grand scheme of things the inside of the house isn't that bad... Broken doors are $50 to replace, 5-10 holes in walls $100 maybe. Ripping out plumbing is a major chore and blatantly obvious.. I'm not as worried about obvious stuff as I am hidden damage.
Carpet and full repaint are expensive, but that's an assumed cost you should be prepared for, and $2-3k maximum.
Water heaters, fridge, dishwasher, all of these other things are a couple hundred and covered by deposit if required. Even major flood damage isn't *that* terrible, I once had a tenant overflow a toilet then leave for 8 hours... Replacing carpet, downstairs ceiling, some insulation was about $1000 at my cost.
But, if I have to replace the hvac I would have to have hard (IE impossible) proof that the tenants did it. Major HVAC issues are a big deal because you can't have a tenant wait for 3 weeks while you try to fix it.
Truly, having someone 'mess' with the heat and AC is probably my biggest concern as a landlord.
