Temps While Encoding Video?
We dont care about your idle, put your CPU to 100 percent load and tell us what the load temp is. Try Aida64 stability test. gl
Just remembered you have a 870 too. Those chips run hot, 80c is common, 75 is warm.
O!!! I had not factored that in!!!!!!!! That---here it comes---was AWESOME. :wub:
I got stupidly addicted to seeing temps 26-29 at idle, and had NO PERSPECTIVE. Forget re our individual chip!!!
(LUV THIS CHIP, tho I do wish it had integrated graphics, cause I honestly don need discreet... but can't have everything)
Mine hits as high as low 70's during extended rendering via CPU (overclocked from 133bclk to 207 bclk 24 X 7).. nothing to worry about..
Well! All this input is actually curing my paranoia! A VERITABLE MIRACLE!!!
I mean it. And that Core Temp app looks way better than Speed Fan! I need this app; I must get this app!
PS: Just struck me, bet some paranoia owes to simple ignorance. In this thing, mine sure did!!!!
lol so good
edit: I knew I remembered you: http://forums.anandtech.com/showthread.php?p=35524992
I love your threads
I am again, unexpectedly really, really moved. In fact, I floated up to the ceiling and am having trouble typing from there!()🙂
A guy----with the emotional health and courage, given how many guys are conditioned to be otherwise---to be ingenuous, is both sadly uncommon, and so, SOOO precious!!! :wub:
It also marks an intact capacity for joy. ALL, HUGE blessings!!!:biggrin:
OK wait. I can't find a site to get this Core Temp app free of sneakies, i.e., InstalIlQ.
http://alcpu.com/CoreTemp/
I understand and respect freewares have to have some way of supporting themselves, but there are some with add ons/toolbars, etc. you can decline during installation, and others who sneak in stuff like above.
But I want this thing, so, maybe I will just go ahead anyhow.
______________________________________________
Edit: K, I think I was able to decline the add ons. But sometimes u think you have, and then, there they are anyhow. No biggie, if things I do not want snuck in, I will find a way of getting rid of them.()🙂
I remember it being clean.
If you want lower temps, speedfan can max your fans to 100%, but it is loud and wears out the fans. Just letting you know. 😛
As it turned out, it kinda was. Clean. I just hadda make sure I declined the add ons. but at least, it listened. Not all freewares with add ons do.
Thanks for this!
Thanks for this!
Your ninja edit makes me look stupid. You edited before I quoted apparently, and I didn't notice. 😛
"NINJA EDIT"!!!!! U should sell that stuff on ebay! Anyone nuanced would bid!!🙂
For anyone who writes for a living, and things are always progressing/presenting in the brain, editing is 3/4 of the deal.
And.....for ME, it is also my form of GAMING!()🙂 One which doesn't raise my THERMALS.:sneaky:😀
New thought: know those ankle thingies they put on people under House Arrest to monitor their activity? (I know from movies.:sneaky🙂
I should get one of those for my left wrist to monitor how often I open thermal monitoring apps. If it's more than once a day, a SWAT team will arrive.:|
I like it!:biggrin:
NEW CONFUSION. I don wanna make a new thread re this, plus, someone here encouraged me to overclock my Lynnfield, and discussion on overclocking progressed from there.....but I am trying to break my addiction to running thermal monitoring apps, so I just ran CPUZ instead. (It's progress, it is!:sneaky🙂
And suddenly, I see my "core speed" is listed at 3588. WUT?😱 So I tried to delve online to understand how core speed is related to clock speed.....and I found nuthin.
What is core speed?
What is core speed?
Same thing as clock AFAIK. The 870 is not an unlocked model though so you will need to overclock through the FSB, which overclocks ram too I think. It also means you will not be able to hit as hight clocks as usual, I think 4.0 is achievable though. The first gen core i series had soldered IHS so overclocks should stay a bit more stable temp wise.
Small threadjack; anyone know of an unlocked bios I could flash to my OEM dell mobo? I don't know the brand, but I could check soon.
OK. Here's what I am now not getting having seen what I put up. All along, this chip was identified as i7 870 2.93.
Suddenly, if core speed is same as clock speed as u suggest--- and if so they should call it one thing---I see much higher numbers! Can U get why I am now confused?
Plus I don wanna overclock anything. U think the original owner overclocked my chip?????😱
Re yr OEM Dell mobo, can you elaborate??? And, I do not know what an unlocked bios is. What is it?
When this system arrived and I hooked it up, first, I went to both Dell and Intel and updated drivers and flashed the bios to the early 2013 version which was available, cause the one I had was outdated.
And, if you mean checking on if the Dell mobo in question is made for Dell by Intel or ASUS, cause they are either one or the other, you will never find out even using the part number. Cause I have tried.
It's intel turbo boost. It auto overclocks itself when it needs to, perfectly fine.
It allows you to overclock, mine does not allow it. I think mine has a logo on it.
O! OK, now.....just IN THIS VERY THREAD, after delving, I learned about the reality of Turboboost versus manual overclocking via the best tutorial ever written. And the former can not even come close to the latter: manual overclocking.
But more important, re the screenie I put up.....when I ran that app, the system was at idle.....so, why would Turboboost even have opened one eye? Much less raised the speed to what I see?
Now, I also now see "multiplier" at 27. And, if I get what that is, it seems to be at the top of the scale. Is it? And if, so, how did it get there? I did not fiddle with any of this! U think the original owner did? U think it is fiddled with????
Re yr Dell mobo.....is this an actual computer? Or a spare board?
Forget cavalier humans who do not know specifics, and s,o who diss Dell mobos (and all things Dell), their boards are generally excellent. One or two exceptions, i.e., the Opti 755, I believe.
You don't have anything to worry about; My workstation runs about 88C running Povray and handbrake at once on 12 cores... one of the nice things to come from Ivy Xeons was all-turbo that works.
The 870 was/is a hell of a CPU; IMO up there with the i7-920 and Q6600.
Helper people? PLEASE, someone who understands this weigh in, cause I have new paranoia that the original owner of this system overclocked it!!!
Why else would this core speed thingy show up so high at idle in PU-Z????? How else can it be explained?????
Given what I recently learned via dense tutorial, no way could it be just Turboboost. Maybe, under load, but at idle??????
COULD IT???
First, let me say with real happiness, I more than welcome, I CELEBRATE this normal post. That I had to put ANYONE on some ignore list, was atypical if not unique, and a very unhappy thing. (Tho I did not included the pug.()🙂) I have now taken you off, and that.....is a HAPPY THING!
I now do get the reality of my former paranoia re temps, and it is abating!
And, thanks so much for your objective take on this chip. When long ago, I posted celebrating it, I was dissed by some sadly held hostage by investing what feels like their whole identity in how fast, how current their systems are.
No form of (forgive this), weenie wagging earns respect given what all of it is emblematic of, and the above is one for sure.
Now, given you have emerged as normal and worthy (Yay!), can U pls look at my last post and help me get clear re if this system was overclocked by the original owner??????
Thanks!!!!🙂
Helper people? PLEASE, someone who understand this weigh in, cause I have new paranoia that the original owner of this system overclocked it!!!
COULD IT???
Cpus are very rarely truly idle, even the os kicks it to boost. 27 is the max multiplier because it is a locked CPU.
O!!!!!!😱 See? That was truly clarifying!!!🙂
But, would that explain the core speed, tho it vacillates some as you watch it, in CPU-Z????? Cause it is way higher than the speed this chip was engineered to function at, no?
And, pls say more about yr Dell mobo; if it's a spare board, if it's in an actual system, etc., and what are you goals for it?
K.....I just had sudden instinct to run Everest. Never hit the flame button re overclocking before.
It indicates overclocking between 13 and 18%. Sooo, if thes high core speed numbers owe simply to Turboboost, I feel WAY better, and I have new respect for Turboboost, cause it does not impose some Fascist agenda on the chip, it responds with sensitivity to load, BUT, it really does work. RIGHT?
But is the above RIGHT? That all yr info is right and nobody messed with my clockspeed?
I learn stuff every second.:\ Well, try to.
From your screenshots, it looks like you're running Win 7. If so, be sure to get the Core Temp sidebar gadget. The program runs in the background, and the gadget shows you CPU usage, temps per core, and other useful information. I have it running all the time, and it uses very little screen real estate.
I do now have something which shows the same. So finally, cause of input in this thread, I am no longer hysterical about temps.🙂 Well, a lot less hysterical.()🙂
Yes, I am running W7, and wild horses could not get me to "upgrade"..."given, re 8, 8.1, that is a euphemism.:sneaky:
Course I am a perfect human, so just maybe, I would consider "upgrading" for the numbers matched, '67 big block, Tri power Vette of my dreams.😎:sneaky:
