Elcs
As some of you may have seen, I have installed a Thermalright HR-03 GT with AC Turbo Module onto my HD4870.
The AC Turbo Module has a 3-pin fan header and the socket on my HD4870 looks like a mini-4-pin PWM socket.
I would like my AC Turbo Module to react to the GPU temperature ie. when it gets to a certain temperature, spin up to X speed and if it continues to rise Y speed then finally Z speed.
From my understanding, if I got a 3-pin to 4-pin, I could plug it directly into my HD4870 and in some roundabout fashion use that to moderate the speed. I could also plug it into a fan header on my motherboard but then I would be stuck for a program that reads GPU temperature and allows a fan to be controlled as depends on the temperature.
I am also thinking about doing this for my CPU fan and Exhaust fan later. My primary concern at this moment in time is my GPU fan.
How would I go about this in the best fashion? Any suggestions?
