I recently got a new hard drive (Raptor 150gig) which replaced an older Rapter 1st generation drive. I had also bought an enzotech heatsink, which turned out to be too large for my case. After determining this I resat the chip and heatsink using the stock heatsink, and plugged in the wires for my hard drives changing the setup to allow better airflow. Now my case is running 5-6 degrees warmer than it had in the past. I installed speedfan to get better readings and apparently they are as follows:
(Programs running: Itunes (playing), Instant Messanger, Speedfan, Steam (the interface, no games loaded), Firefox (3 Tabs), ESET Anti-virus)
System: 52 C
CPU: 51 C
AUX: 54 C
HD0: 40 C (Raptor 150GIG)
HD1: 34 C (Seagate 400GIG)
HD2: 37 C (Raptor 74GIG)
Temp1: 40 C
Core: 33 C
When I shut all of the above programs down, the temperature only drops by 1-2 degrees max. All of these heat issues started when I went into my case and changed things. Could it have something to do with the fact that my room is very warm right now? It's maybe 70 F outside, and my room as always is probably warmer than that. Could those temperatures running at constant be damaging to my system? I know the System/CPU/AUX temps are way too hot, staying 50+ even when idle.
System: 52 C
CPU: 51 C
AUX: 54 C
Temp1: 40 C
Core: 33 C
