3DVagabond
Which STILL doesn't address the fundamental hardware change required on desktop displays, which AMD has said nothing about a plan to address and has been very hesitant to actually acknowledge (but did do so, when pressed by tech reporters).
AMD doesn't make monitors. They are updating the standard to make "Free-Sync" work on any monitor that adheres to the standard.
Yeah, but that is simply not true. Whether AMD intentionally or unintentionally misled is a question one might ask. As it is very clear that existing standards are not gonna cut it. The link 3D posted is undeniable.
If you continue to say freesync uses existing standards then you are continuing to spread misinformation. Its that simple.
Updating the DisplayPort standard for freesync means that current hardware out today will not work either. So current HW is out of the question too. You will have to buy new HW for freesync. And we dont even have an approval, just a request for the standard to be changed.
Freesync is a ways out. Its not existing standards on existing tech. Nvidia told us it wouldnt work like AMD claimed and now we can all see this. Desktop panels cannot do this in their current state. It is absolutely not as simple as AMD made it sound at CES. The whole point was to downplay Gsync. But as we can already see, there is no way to do this on the desktop in its current form.
AMD said that it might be possible for some monitors to be retrofitted with a firmware update. They would know better since they designed the DP standard. I never said it uses existing standards.
I'm not saying that it will magically work on existing monitors. A monitor will obviously have to be DP1.2a compliant. Thing is, it's not going to be put on individual models at ~$200 extra for the feature and only work with certain nVidia cards. It will work with any DP1.2a compliant set of devices (monitor and graphics card). Surely better than the currently proposed G-Sync.
All I was actually addressing was the fact that AMD is actively pursuing bringing Free-Sync to market. Unlike what some would have us believe. As far as the likelihood of acceptance goes, come on, what's the likelihood that it won't be? DP is AMD's standard that they gave to the industry. Why would VESA not make the changes?
