Tech Arp HD Benchmark 3.0 was released today!!
Qbah
3,754
10
This is my stock run at 2.67GHz.
x264 HD BENCHMARK 3.0 RESULTS
Please do not compare it with older versions of the benchmark!
Please copy/paste everything below the line to to report your data
Results for x264.exe r1342
encoded 1442 frames, 54.42 fps, 3900.68 kb/s
encoded 1442 frames, 50.80 fps, 3900.68 kb/s
encoded 1442 frames, 55.44 fps, 3901.21 kb/s
encoded 1442 frames, 53.52 fps, 3900.68 kb/s
encoded 1442 frames, 14.91 fps, 3971.45 kb/s
encoded 1442 frames, 14.76 fps, 3970.48 kb/s
encoded 1442 frames, 16.92 fps, 3971.65 kb/s
encoded 1442 frames, 14.84 fps, 3972.16 kb/s
System Details
Name Intel Core 2 Quad Q9450
Codename Yorkfield
Specification Intel(R) Core(TM)2 Quad CPU Q9450 @ 2.66GHz
Core Stepping C1
Technology 45 nm
manufacturer Gigabyte Technology Co., Ltd.
vendor Gigabyte Technology Co., Ltd.
Stock frequency 2666 MHz
Core Speed 2666.9 MHz
FID range 6.0x - 8.0x
Northbridge Intel P35/G33/G31 rev. A2
Southbridge Intel 82801IR (ICH9R) rev. 02
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 5
RAS# Precharge (tRP) 5
Cycle Time (tRAS) 18
Command Rate (CR) 2T
Memory Frequency 400.0 MHz (5:6)
Memory Type DDR2
Memory Size 4096 MBytes
Channels Dual, (Symmetric)
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7100)
Number of processors 1
Number of threads 4
Number of threads 4 (max 4)
L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
Package (platform ID) Socket 775 LGA (0x4)
Temperature 0 33°C (91°F) [0x21] (System)
Temperature 1 31°C (87°F) [0x1F] (CPU)
Temperature 0 43°C (109°F) [0x39] (Core #0)
Temperature 1 44°C (111°F) [0x38] (Core #1)
Temperature 2 44°C (111°F) [0x38] (Core #2)
Temperature 3 47°C (116°F) [0x35] (Core #3)
nyker96
5,630
I just noticed that the stock i7 920 is much faster than stock i5 750, looks like the superior memory bandwidth of i7 pays off on certain tasks.
edplayer
2,186
and i5 is quicker than Q9550. That Athlon II X2 240 has good numbers considering how cheap the cpu is (and only being a dual core)(edit: just realized that his is at 3.78GHz, make me feel a lot better :)). Fry's had that with a motherboard for $40 today! Can someone post their Phenom II scores at stock please?
Here is mine:
encoded 1442 frames, 62.91 fps, 3900.68 kb/s
encoded 1442 frames, 63.12 fps, 3900.96 kb/s
encoded 1442 frames, 63.43 fps, 3900.68 kb/s
encoded 1442 frames, 63.13 fps, 3900.44 kb/s
encoded 1442 frames, 19.28 fps, 3971.28 kb/s
encoded 1442 frames, 19.21 fps, 3971.62 kb/s
encoded 1442 frames, 19.21 fps, 3970.90 kb/s
encoded 1442 frames, 19.27 fps, 3971.57 kb/s
System Details
Name Intel Core 2 Quad Q9550
Codename Yorkfield
Specification Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz
Core Stepping E0
Technology 45 nm
Stock frequency 2833 MHz
Core Speed 2833.2 MHz
FID range 6.0x - 8.5x
Northbridge Intel P45/P43/G45/G43 rev. A2
Southbridge Intel 82801JR (ICH10R) rev. 00
Memory Type DDR2
Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
Number of threads 4
Temperature 0 36°C (96°F) [0x24] (System)
Temperature 1 56°C (132°F) [0x38] (CPU)
Temperature 0 69°C (156°F) [0x1F] (Core #0)
Temperature 3 65°C (148°F) [0x23] (Core #3)
Temperature 2 64°C (147°F) [0x24] (Core #2)
Temperature 1 59°C (138°F) [0x29] (Core #1)
Temps are high (stock HSF). Case is a Sonata III with the single stock 120mm set to low, non exhausting 9600GT and four drives in there.
Rhoxed
1,051
and i5 is quicker than Q9550. That Athlon II X2 240 has good numbers considering how cheap the cpu is (and only being a dual core). Fry's had that with a motherboard for $40 today! Can someone post their Phenom II scores at stock please?
a phenom II at which stock speed?
i have a 940BE and a 720BE unlocked, would you like both 2.8 and 3ghz ran?
Rhoxed
1,051
Here is my 940BE at stock, i will run the 720BE in a few, sorry it will be ran as a quad core because once unlocked i dont want to mess with the AMD gods to test in 3core =]
encoded 1442 frames, 64.37 fps, 3900.68 kb/s
encoded 1442 frames, 64.57 fps, 3901.21 kb/s
encoded 1442 frames, 64.03 fps, 3900.68 kb/s
encoded 1442 frames, 64.86 fps, 3900.68 kb/s
encoded 1442 frames, 18.99 fps, 3970.65 kb/s
encoded 1442 frames, 19.09 fps, 3971.81 kb/s
encoded 1442 frames, 18.77 fps, 3970.64 kb/s
encoded 1442 frames, 18.57 fps, 3971.77 kb/s
System Details
Name AMD Phenom II X4 940
Codename Deneb
Specification AMD Phenom(tm) II X4 940 Processor
Core Stepping RB-C2
Technology 45 nm
Core Speed 3000.3 MHz
Northbridge AMD 790FX rev. 00
Southbridge ATI SB600 rev. 00
Memory Frequency 533.4 MHz (3:8)
Memory Type DDR2
Channels Dual, (Unganged)
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7264)
Number of threads 4
L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64
Package Socket AM2+ (940)
Package Type 0x1
Temperature 0 34°C (93°F) [0x22] (TMPIN0)
Temperature 2 31°C (87°F) [0x1F] (TMPIN2)
Temperature 0 44°C (110°F) [0x15C] (Core #0)
Temperature 1 44°C (110°F) [0x15C] (Core #1)
Temperature 2 44°C (110°F) [0x15C] (Core #2)
Temperature 3 44°C (110°F) [0x15C] (Core #3)
Rhoxed
1,051
and the 720BE unlocked at stock (think of it more like a Phenom II 920)
encoded 1442 frames, 60.16 fps, 3900.68 kb/s
encoded 1442 frames, 60.84 fps, 3900.68 kb/s
encoded 1442 frames, 61.30 fps, 3900.68 kb/s
encoded 1442 frames, 61.16 fps, 3900.68 kb/s
encoded 1442 frames, 17.19 fps, 3970.62 kb/s
encoded 1442 frames, 17.41 fps, 3971.57 kb/s
encoded 1442 frames, 16.96 fps, 3970.65 kb/s
encoded 1442 frames, 17.07 fps, 3971.05 kb/s
System Details
Codename Deneb
Specification AMD Phenom(tm) II X4 20 Processor
Core Stepping RB-C2
Technology 45 nm
Core Speed 2814.1 MHz
Northbridge AMD 790X rev. 00
Southbridge ATI SB750 rev. 00
Cycle Time (tRAS) 15
Memory Frequency 536.0 MHz (3:8)
Memory Type DDR2
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7227)
Number of threads 4
Package Type 0x1
Temperature 0 39°C (102°F) [0x27] (TMPIN0)
Temperature 1 49°C (120°F) [0x31] (TMPIN1)
Temperature 2 41°C (105°F) [0x29] (TMPIN2)
Temperature 0 0°C (32°F) [0x0] (Core #0)
Temperature 1 0°C (32°F) [0x0] (Core #1)
Temperature 2 0°C (32°F) [0x0] (Core #2)
Temperature 3 0°C (32°F) [0x0] (Core #3)
james1701
1,791
34
encoded 1442 frames, 55.02 fps, 3901.21 kb/s
encoded 1442 frames, 64.32 fps, 3901.21 kb/s
encoded 1442 frames, 64.55 fps, 3901.21 kb/s
encoded 1442 frames, 65.55 fps, 3901.21 kb/s
encoded 1442 frames, 18.22 fps, 3970.78 kb/s
encoded 1442 frames, 21.02 fps, 3971.53 kb/s
encoded 1442 frames, 21.07 fps, 3971.61 kb/s
encoded 1442 frames, 20.98 fps, 3971.65 kb/s
System Details
Name Intel Core 2 Quad Q6600
Codename Kentsfield
Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Core Stepping G0
Technology 65 nm
Manufacturer (ID) Crucial Technology (7F7F7F7F7F9B0000)
Stock frequency 2400 MHz
Core Speed 3375.6 MHz
FID range 6.0x - 9.0x
CAS# latency (CL) 6.0
RAS# to CAS# delay (tRCD) 6
RAS# Precharge (tRP) 6
Memory Frequency 375.1 MHz (1:1)
Memory Type DDR2
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
Number of threads 4
L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
Temperature 0 36°C (96°F) [0x24] (TMPIN0)
Temperature 1 25°C (76°F) [0x19] (TMPIN1)
Temperature 0 54°C (129°F) [0x2E] (Core #0)
Temperature 1 51°C (123°F) [0x31] (Core #1)
Temperature 2 48°C (118°F) [0x34] (Core #2)
Temperature 3 51°C (123°F) [0x31] (Core #3)
hdfxst
851
for reference here's my x2 240 at stock speed
encoded 1442 frames, 40.71 fps, 3899.26 kb/s
encoded 1442 frames, 40.58 fps, 3899.26 kb/s
encoded 1442 frames, 40.66 fps, 3899.26 kb/s
encoded 1442 frames, 9.47 fps, 3971.47 kb/s
encoded 1442 frames, 9.54 fps, 3971.07 kb/s
encoded 1442 frames, 9.42 fps, 3971.74 kb/s
encoded 1442 frames, 9.54 fps, 3971.81 kb/s
System Details
Name AMD Athlon II X2 240
Codename Regor
Specification AMD Athlon(tm) II X2 240 Processor
Core Stepping BL-C2
Technology 45 nm
Stock frequency 2800 MHz
Core Speed 2803.7 MHz
FID range 5.0x - 14.0x
Northbridge ATI RD770 rev. 00
Southbridge ATI SB700 rev. 00
Memory Frequency 534.0 MHz (1:2)
Memory Type DDR2
Windows Version Microsoft Windows XP Home Edition Service Pack 3 (Build 2600)
Number of threads 2
Number of threads 2 (max 2)
L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size
Package Type 0x1
Temperature 0 23°C (73°F) [0x17] (TMPIN0)
Temperature 1 24°C (75°F) [0x18] (TMPIN1)
Temperature 2 78°C (172°F) [0x4E] (TMPIN2)
Temperature 0 22°C (70°F) [0xAC] (Core #0)
Temperature 1 22°C (71°F) [0xB0] (Core #1)
Tsavo
2,645
37
The 920 in this thread is running at 4 GHz.
Rhoxed
1,051
i would like to see some phenom II's with DDR3, interested to see how big of a role RAM speed is in this bench.
Oct 4, 2004
10,515
Have any Core i7 users tried this benchmark with and without Hyperthreading enabled? I'm guessing improves things between 15-20%? Yes, no...maybe?
SRoode
243
My main PC:
encoded 1442 frames, 70.72 fps, 3900.68 kb/s
encoded 1442 frames, 70.56 fps, 3900.68 kb/s
encoded 1442 frames, 70.94 fps, 3900.68 kb/s
encoded 1442 frames, 71.15 fps, 3901.21 kb/s
encoded 1442 frames, 20.65 fps, 3971.78 kb/s
encoded 1442 frames, 20.74 fps, 3971.11 kb/s
encoded 1442 frames, 20.76 fps, 3972.01 kb/s
encoded 1442 frames, 20.87 fps, 3972.08 kb/s
System Details
Codename Kentsfield
Specification Intel(R) Core(TM)2 Quad CPU Q6600@2.40GHz
Core Stepping G0
Technology 65 nm
Core Speed 3205.9 MHz
Memory Frequency 549.6 MHz (5:6)
Memory Type DDR2
Memory Size 8192 MBytes
Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600)
Number of threads 4
Temperature 0 31°C (87°F) [0x1F] (SYSTIN)
Temperature 1 29°C (84°F) [0x3A] (CPUTIN)
Temperature 0 40°C (103°F) [0x28] (CPU)
Temperature 1 34°C (93°F) [0x22] (System)
Temperature 2 54°C (129°F) [0x36] (PWM)
Temperature 0 46°C (114°F) [0x36] (Core #0)
Temperature 2 40°C (103°F) [0x3C] (Core #2)
Temperature 3 43°C (109°F) [0x39] (Core #3)
And, my road PC:
encoded 1442 frames, 57.92 fps, 3899.26 kb/s
encoded 1442 frames, 58.39 fps, 3899.26 kb/s
encoded 1442 frames, 58.25 fps, 3899.26 kb/s
encoded 1442 frames, 56.68 fps, 3899.26 kb/s
encoded 1442 frames, 14.68 fps, 3971.39 kb/s
encoded 1442 frames, 14.85 fps, 3970.73 kb/s
encoded 1442 frames, 13.83 fps, 3971.12 kb/s
encoded 1442 frames, 14.42 fps, 3971.07 kb/s
System Details
Name Intel Core 2 Duo E8600
Codename Wolfdale
Specification Intel(R) Core(TM)2 Duo CPU E8600 @ 3.33GHz
Core Stepping E0
Technology 45 nm
Stock frequency 3333 MHz
Core Speed 4319.9 MHz
FID range 6.0x - 10.0x
Northbridge Intel P45/P43 rev. A3
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 24
Memory Frequency 800.0 MHz (3:5)
Memory Type DDR3
Number of threads 2
L2 cache 6144 KBytes, 24-way set associative, 64-byte line size
Package (platform ID) Socket 775 LGA (0x0)
Temperature 0 38°C (100°F) [0x26] (TMPIN0)
Temperature 1 52°C (125°F) [0x34] (TMPIN1)
Temperature 0 55°C (130°F) [0x2D] (Core #0)
eelw
10,343
5,494
Hmm, it is around 20% But why is the first pass slower with HT on?
HT on
encoded 1442 frames, 89.86 fps, 3899.02 kb/s
encoded 1442 frames, 92.84 fps, 3899.02 kb/s
encoded 1442 frames, 91.47 fps, 3899.02 kb/s
encoded 1442 frames, 91.10 fps, 3899.02 kb/s
encoded 1442 frames, 37.95 fps, 3963.25 kb/s
encoded 1442 frames, 37.93 fps, 3961.57 kb/s
encoded 1442 frames, 37.90 fps, 3963.31 kb/s
encoded 1442 frames, 37.85 fps, 3957.70 kb/s
HT off
encoded 1442 frames, 101.64 fps, 3900.89 kb/s
encoded 1442 frames, 101.75 fps, 3900.43 kb/s
encoded 1442 frames, 101.75 fps, 3900.68 kb/s
encoded 1442 frames, 100.97 fps, 3900.93 kb/s
encoded 1442 frames, 31.58 fps, 3971.73 kb/s
encoded 1442 frames, 31.53 fps, 3971.53 kb/s
encoded 1442 frames, 31.67 fps, 3970.74 kb/s
encoded 1442 frames, 31.58 fps, 3971.39 kb/s
Rubycon
Madame President
Aug 10, 2005
17,768
485
Turbo locked ON! :)
encoded 1442 frames, 104.92 fps, 3899.02 kb/s
encoded 1442 frames, 105.88 fps, 3899.02 kb/s
encoded 1442 frames, 103.52 fps, 3899.02 kb/s
encoded 1442 frames, 104.57 fps, 3899.02 kb/s
encoded 1442 frames, 41.21 fps, 3962.99 kb/s
encoded 1442 frames, 41.36 fps, 3961.09 kb/s
encoded 1442 frames, 41.12 fps, 3961.99 kb/s
encoded 1442 frames, 41.38 fps, 3960.13 kb/s
System Details
Name Intel Xeon W3520
product System Product Name
Codename Bloomfield
Specification Intel(R) Xeon(R) CPU W3520 @ 2.67GHz
Specification PC3-12800
Core Stepping D0
Technology 45 nm
Core Speed 4426.6 MHz
Northbridge Intel X58 rev. 13
CAS# latency (CL) 7.0
RAS# to CAS# delay (tRCD) 7
RAS# Precharge (tRP) 7
Cycle Time (tRAS) 20
Command Rate (CR) 1T
Command Rate 1T
Command Rate 1T
Command Rate 1T
Command Rate 1T
Command Rate 1T
Command Rate 1T
Memory Frequency 843.2 MHz (2:8)
Memory Type DDR3
Memory Size 12288 MBytes
Channels Triple
Windows Version Microsoft Windows 7 (6.1) Enterprise Edition (Build 7600)
Number of threads 8
Number of threads 8 (max 16)
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T
Package (platform ID) Socket 1366 LGA (0x1)
Temperature 0 41°C (105°F) [0x29] (SYSTIN)
Temperature 1 54°C (129°F) [0x6C] (CPUTIN)
Temperature 0 65°C (148°F) [0x23] (Core #0)
Temperature 1 56°C (132°F) [0x2C] (Core #1)
Temperature 2 65°C (148°F) [0x23] (Core #2)
Temperature 3 55°C (130°F) [0x2D] (Core #3)
Hyperlite
5,664
encoded 1442 frames, 56.00 fps, 3900.68 kb/s
encoded 1442 frames, 56.34 fps, 3900.68 kb/s
encoded 1442 frames, 55.06 fps, 3901.21 kb/s
encoded 1442 frames, 54.09 fps, 3900.68 kb/s
encoded 1442 frames, 14.10 fps, 3971.09 kb/s
encoded 1442 frames, 15.23 fps, 3971.70 kb/s
encoded 1442 frames, 15.16 fps, 3971.67 kb/s
encoded 1442 frames, 15.38 fps, 3971.33 kb/s
System Details
Name AMD Athlon II X4 620
Codename Propus
Specification AMD Athlon(tm) II X4 620 Processor
Core Stepping
Technology 45 nm
Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000)
Stock frequency 2600 MHz
Core Speed 3406.0 MHz
FID range 5.0x - 13.0x
Northbridge AMD 785GX rev. 00
CAS# latency (CL) 8.0
RAS# to CAS# delay (tRCD) 8
RAS# Precharge (tRP) 8
Cycle Time (tRAS) 22
Memory Frequency 698.7 MHz (3:8)
Memory Type DDR3
Windows Version Microsoft Windows 7 (6.1) (Build 7600)
Number of threads 4
Package Type 0x1
Temperature 0 37°C (98°F) [0x25] (TMPIN0)
Temperature 1 62°C (143°F) [0x3E] (TMPIN1)
Temperature 2 57°C (134°F) [0x39] (TMPIN2)
Temperature 0 57°C (134°F) [0x1C7] (Core #0)
Temperature 1 57°C (134°F) [0x1C7] (Core #1)
Temperature 2 57°C (134°F) [0x1C6] (Core #2)
Temperature 3 57°C (134°F) [0x1C6] (Core #3)
E6700
208
encoded 1442 frames, 96.37 fps, 3901.21 kb/s
encoded 1442 frames, 95.57 fps, 3900.68 kb/s
encoded 1442 frames, 96.26 fps, 3900.68 kb/s
encoded 1442 frames, 96.93 fps, 3900.68 kb/s
encoded 1442 frames, 29.99 fps, 3970.99 kb/s
encoded 1442 frames, 29.89 fps, 3971.18 kb/s
encoded 1442 frames, 30.00 fps, 3972.00 kb/s
encoded 1442 frames, 29.92 fps, 3971.89 kb/s
System Details
Name Intel Core i5 750
Codename Lynnfield
Specification Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
Core Stepping B1
Technology 45 nm
Core Speed 3999.9 MHz
Northbridge Intel DMI Host Bridge rev. 11
Southbridge Intel P55 rev. 05
Command Rate 2T
Command Rate 2T
Memory Frequency 800.0 MHz (2:8)
Memory Type DDR3
Channels Dual
Number of threads 4
Number of threads 4 (max 16)
Package (platform ID) Socket 1156 LGA (0x1)
Temperature 2 52°C (125°F) [0x34] (TMPIN2)
Temperature 0 62°C (143°F) [0x25] (Core #0)
Temperature 1 50°C (121°F) [0x31] (Core #1)
Temperature 2 58°C (136°F) [0x29] (Core #2)
Temperature 3 59°C (138°F) [0x28] (Core #3)
Cattykit
521
encoded 1442 frames, 83.80 fps, 3899.02 kb/s
encoded 1442 frames, 83.41 fps, 3899.02 kb/s
encoded 1442 frames, 83.04 fps, 3899.02 kb/s
encoded 1442 frames, 84.43 fps, 3899.02 kb/s
encoded 1442 frames, 34.16 fps, 3955.30 kb/s
encoded 1442 frames, 33.89 fps, 3971.68 kb/s
encoded 1442 frames, 33.62 fps, 3971.24 kb/s
encoded 1442 frames, 33.95 fps, 3961.70 kb/s
System Details
Name Intel Core i7 860
Codename Lynnfield
Specification Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
Core Stepping B1
Technology 45 nm
Core Speed 3711.9 MHz
Command Rate 2T
Command Rate 2T
Command Rate 2T
Command Rate 2T
Memory Frequency 742.4 MHz (2:8)
Memory Type DDR3
Channels Dual
Number of threads 8
Temperature 0 56°C (132°F) [0x38] (SYSTIN)
Temperature 1 56°C (132°F) [0x70] (CPUTIN)
Temperature 2 41°C (104°F) [0x51] (AUXTIN)
Temperature 0 52°C (125°F) [0x2F] (Core #0)
Temperature 1 45°C (112°F) [0x36] (Core #1)
Temperature 2 51°C (123°F) [0x30] (Core #2)
Temperature 3 52°C (125°F) [0x2F] (Core #3)
KLin
30,449
752
Well I decided that I needed a w3520.
encoded 1442 frames, 91.88 fps, 3897.87 kb/s
encoded 1442 frames, 88.54 fps, 3899.02 kb/s
encoded 1442 frames, 92.62 fps, 3898.50 kb/s
encoded 1442 frames, 90.45 fps, 3899.02 kb/s
encoded 1442 frames, 36.89 fps, 3959.21 kb/s
encoded 1442 frames, 37.12 fps, 3966.36 kb/s
encoded 1442 frames, 37.08 fps, 3961.68 kb/s
encoded 1442 frames, 37.14 fps, 3960.31 kb/s
System Details
Codename Bloomfield
Core Stepping D0
Technology 45 nm
Core Speed 4000.0 MHz
Command Rate 2T
Command Rate 2T
Command Rate 2T
Memory Frequency 600.0 MHz (2:6)
Memory Type DDR3
Memory Size 6144 MBytes
Channels Triple
Number of threads 8
Temperature 0 38°C (100°F) [0x26] (SYSTIN)
Temperature 1 55°C (130°F) [0x6E] (CPUTIN)
Temperature 0 62°C (143°F) [0x26] (Core #0)
Temperature 1 63°C (145°F) [0x25] (Core #1)
Temperature 3 57°C (134°F) [0x2B] (Core #3)
The temps aren't accurate. I observed my temps on cores 1 and 3 getting into the low 80's.
Tsavo
2,645
37
encoded 1442 frames, 37.50 fps, 3899.26 kb/s
encoded 1442 frames, 37.51 fps, 3899.26 kb/s
encoded 1442 frames, 37.26 fps, 3899.26 kb/s
encoded 1442 frames, 36.72 fps, 3899.26 kb/s
encoded 1442 frames, 9.24 fps, 3971.66 kb/s
encoded 1442 frames, 9.27 fps, 3970.62 kb/s
encoded 1442 frames, 9.28 fps, 3970.89 kb/s
encoded 1442 frames, 9.30 fps, 3970.77 kb/s
System Details
Name Intel Celeron
Codename Wolfdale
Specification Intel(R) Celeron(R) CPU E3200 @ 2.40GHz OVERCLOCKED to 3 GHz.
Core Stepping R0
Technology 45 nm
Core Speed 3009.7 MHz
FID range 6.0x - 12.0x
Northbridge Intel G41 rev. A3
Southbridge Intel 82801GB (ICH7/R) rev. A1
Memory Frequency 501.6 MHz (1:2)
Memory Type DDR2
Memory Size 2048 MBytes
Number of threads 2
L2 cache 1024 KBytes, 4-way set associative, 64-byte line size
Temperature 0 36°C (96°F) [0x24] (SYSTIN)
Temperature 1 61°C (141°F) [0x7A] (CPUTIN)
Temperature 2 49°C (120°F) [0x62] (AUXTIN)
Temperature 0 59°C (138°F) [0x29] (Core #0)
Temperature 1 57°C (134°F) [0x2B] (Core #1)
desolate
113
encoded 1442 frames, 67.04 fps, 3900.68 kb/s
encoded 1442 frames, 65.60 fps, 3900.68 kb/s
encoded 1442 frames, 65.86 fps, 3901.21 kb/s
encoded 1442 frames, 65.34 fps, 3900.68 kb/s
encoded 1442 frames, 21.08 fps, 3970.55 kb/s
encoded 1442 frames, 21.20 fps, 3971.61 kb/s
encoded 1442 frames, 21.11 fps, 3970.75 kb/s
encoded 1442 frames, 21.36 fps, 3971.20 kb/s
System Details
Name Intel Xeon X3210
Codename Kentsfield
Specification Intel(R) Xeon(R) CPU X3210 @ 2.13GHz
Core Stepping G0
Technology 65 nm
Stock frequency 2133 MHz
Core Speed 3504.0 MHz
Memory Frequency 438.0 MHz (1:1)
Memory Type DDR2
Number of threads 4
Temperature 0 48°C (118°F) [0x30] (System)
Temperature 1 72°C (161°F) [0x48] (CPU)
Temperature 0 81°C (177°F) [0x13] (Core #0)
Temperature 1 81°C (177°F) [0x13] (Core #1)
Temperature 2 80°C (175°F) [0x14] (Core #2)
Temperature 3 80°C (175°F) [0x14] (Core #3)
bobross419
1,981
Dell Optiplex 755 SFF - My work computer hehehe, this isn't totally accurate b/c I can't shutdown all the other crap I have running, but figured it would be fun :)
Code:
  encoded 1442 frames, 58.97 fps, 3901.21 kb/s
encoded 1442 frames, 60.12 fps, 3900.68 kb/s
encoded 1442 frames, 59.69 fps, 3900.68 kb/s
encoded 1442 frames, 59.08 fps, 3900.68 kb/s
encoded 1442 frames, 18.10 fps, 3970.80 kb/s
encoded 1442 frames, 18.05 fps, 3971.38 kb/s
encoded 1442 frames, 18.06 fps, 3971.60 kb/s
encoded 1442 frames, 18.06 fps, 3971.63 kb/s
  System Details
        Codename          Yorkfield
        Core Stepping           C1
        Technology        45 nm
        Manufacturer (ID) Nanya Technology (7F7F7F0B00000000)
        Core Speed        2825.9 MHz
  Northbridge             Intel Q35 rev. A2
  Southbridge             Intel 82801IH (ICH9DH) rev. 02
  Memory Frequency        332.5 MHz (1:1)
  Memory Type             DDR2
  Number of threads       4
        Temperature 0     74°C (165°F) [0x1A] (Core #0)
        Temperature 1     65°C (148°F) [0x23] (Core #1)
Allio
1,904
28
Here's one. Unlocked X2 550. Not the fastest thing out but it has to be up there in terms of FPS/$.
Looks to be about 3% faster than the identically clocked X4 965 with DDR2 in the OP.
Edit: but almost exactly the same as your 940 with DDR2? Who knows :p
encoded 1442 frames, 76.77 fps, 3900.68 kb/s
encoded 1442 frames, 76.65 fps, 3900.68 kb/s
encoded 1442 frames, 77.55 fps, 3900.68 kb/s
encoded 1442 frames, 23.49 fps, 3971.40 kb/s
encoded 1442 frames, 23.47 fps, 3970.65 kb/s
encoded 1442 frames, 23.54 fps, 3971.87 kb/s
encoded 1442 frames, 23.40 fps, 3971.81 kb/s
System Details
Codename Deneb
Specification AMD Phenom(tm) II X4 B50 Processor
Specification PC3-14200
Core Stepping RB-C2
Technology 45 nm
Core Speed 3616.3 MHz
Memory Frequency 669.7 MHz (3:10)
Memory Type DDR3
Number of threads 4
Package Type 0x1
Temperature 0 40°C (103°F) [0x28] (TMPIN0)
Temperature 1 50°C (121°F) [0x32] (TMPIN1)
Temperature 2 80°C (175°F) [0x50] (TMPIN2)
Makaveli
4,985
1,577
Those are pretty nice increases in FPS from the first 3 920 post.
From 4.1 to 4.2 to 4.3 Ghz.
