TeAm F@H Project Database
The XP2100, 1G RAM is now working on:
protein............................................Core......Credit....PPD
p2107_lambda_5way_melt_4_10011 Gromacs 404.00 181.80
note: gen (0)
A64 (3200+)
p2106_lambda_5way_melt_4_10011.......Gromacs.....202.....109
Edit: I just thought of a problem with me adding these. I game on this machine as well, I stop F@H all together when I do, so I'm not sure how this will affect these results.
Bunker, I just wanted to get some approximate values for the wu's ppd. There are just too many factors involved to get any real accurate data. For example operating system, ram speed/capacity, cpu type, client optimizations ect.... These can all have an effect on ppd and would just be too difficult to track, so don't worry about it, just the raw ppd is good enough for now 🙂
Xeon (2ghz)
p2107_lambda_5way_melt_4_10011...........Gromacs........404.......78
PIII (866)
p1808_Collagen_Brodsky_refolding..............AMBER...........153.......51
p1809_Collagen_POG10new_refolding..........AMBER...........153.......52
Thanks for the help Spacehead and bunker :thumbsup:
I'm gonna be adding some info on ppd averages of each cpu type when I get some time🙂
Project - p2051_abeta_4mer
Core - Gromacs
Credit - 267
PPD - 59
Project - p2106_lambda_5way_melt_4_10011
Core - Gromacs
Credit - 202
PPD - 60
Thanks Spacehead
I added in some averages for the ppd on cpu types🙂
It would be great if some more people would help out...
Xeon
p2081_p53_in_AGBNP........GBGROMACS......255....91
P3
p1808_Collagen_Brodsky_refolding.......AMBER........153......44
(both processors are running the same protein)
Looks interesting. I have NO clue how to use it. No .exe file...tinkered a bit with the .csv but really no clue how to go about it. I even went to the site and read the forums.
Anyone want to help a newb to this proggy?
Heh, you did the same thing I did the first time I tried downloading it. You downloaded the source files and not the compiled executable.
This link should work for the actual download:
Download
P4 1.7GHZ - TINKER (Yes, I guess this is the only tinker you guys know of!)
PPD Est. 0.26WUs
p1152_L939_K12M_ext_from638
P4 1.7GHZ -Gromacs
Est. PPD 0.22WUs
P3 1GHZ -Gromacs
Est. PPD 0.26WUs
p2306_BBA5_pfold in water
P4 1.7GHZ -Gromacs
Est. PPD 0.16WUs
p2052_abeta_4mer
Pentium M 1.7GHZ -Gromacs
Est. PPD 0.76WUs
p2088_A21_agbnp_amber99
P4 3.5GHZ -Gromacs
Est. PPD 1.21WUs
p2086_A21_agbnp_amber99
Could I be the one who single handedly brings us past "The Knights Who Say Ni!"
I've got a few more lower powered systems as well running FAH, probably about 5 PII/III 450 machines, progress seems slow on these systems and isn't run 24/7. I've got a few more lower powered systems at home I plan I getting FAH to run on in the range of P90-PIII600... So those should help a little bit more...
PIII(866mhz)
p2106_lambda_5way_melt_4_10011.......................GROMACS.....................202............................37
p2107_lambda_5way_melt_4_10011.......................GROMACS.....................404............................37
I hope you're the ONE.
Gravity
PPD Est. 0.26WUs
P4 1.7GHZ -Gromacs
Est. PPD 0.22WUs
P3 1GHZ -Gromacs
Est. PPD 0.26WUs
P4 1.7GHZ -Gromacs
Est. PPD 0.16WUs
p2052_abeta_4mer
Est. PPD 0.76WUs
P4 3.5GHZ -Gromacs
Est. PPD 1.21WUs
Gravity
PPD Est. 0.26WUs
P4 1.7GHZ -Gromacs
Est. PPD 0.22WUs
P3 1GHZ -Gromacs
Est. PPD 0.26WUs
P4 1.7GHZ -Gromacs
Est. PPD 0.16WUs
p2052_abeta_4mer
Est. PPD 0.76WUs
P4 3.5GHZ -Gromacs
Est. PPD 1.21WUs
Lol, gravity... How do you have so many computers!!?!?! So Far I've only got about 11 computers running FAH.. I technically have access to 14 more computers though most of them are albiet slow, it should all help...
Those aren't mine, I was just quoting the thread. I'm working on getting my stats up but I guess I have about 40 or so folding.
It's a work thingy.
Best,
Gravity
