Originally posted by: silverpig
Here's what to do:
Push in the clutch, start the car, put it in 1st, floor the accelerator, drop the clutch.
It's a great way to show off when you leave the dealer.
LOL, I'd break the clutch in first... unless you like a glazed slipping clutch, wheel hop, and broken axles
Also, there is a time when you can downshift while braking... it's mostly for circuit/road racing but I use it on the street for fun. Heel-toe downshifting, it requires rev matching thus to not unsettle the car (less wear on the tranny & no engine braking either). In fact, truckers for the most part is that many of them double clutch when accelerating normally. I do it too, just to save wear and tear on my crappy @$$ synchros.
I personally don't use heel-toe method for hills... it's like brake torquing in an auto. Not very useful if you're good enough with your clutch and throttle plus it stresses your driveline components. I still generally shift to neutral during normal traffic driving.
Like everyone else has said, it's mostly in correct use of the clutch. Get a feel for where your clutch grabs and then you should be able to get the car in motion fairly well. Next would be getting to the point where you can shift 1-2 and sometimes 3-4 (if your gearing is short) without bucking the car. Hills & shifting during a turn should come naturally as you get more and more used to modulating the clutch pedal.
