Tapatalk Problems
T_Yamamoto
15,007
795
Well here are a list of problems I've found. They really need to update.
Quotes the the wrong post, its a completely random post from a completely other thread.
Pictures don't load...only 20% of the time.
Random FCs when signal gets weak
Sometimes doesn't go to first page.
Button lags and they don't work
That's all I've experienced or found.
ponyo
19,688
2,811
Are you completely stock? Did you get the same problem running stock? If not it's likely your buggy rom/kernel/etc rather than the app.
Fingolfin269
17,948
34
I'm using 1.13.1 on iOS and not having issues. The only thing on your list that has happened to me is "sometimes doesn't go to first page" but that is configurable in settings.
Cares
868
None of these problems for me. Probably user error or device compatibility problems..
Mwing
294
Pictures load 15% of the time
Gnex and latest tapatalk
What happened to the app?
Sent from my Galaxy Nexus using Tapatalk
T_Yamamoto
15,007
795
no sustainable revenue model? Everyone that's going to buy it bought it....
well they need to keep supporting it
or are they going to be like microsoft.
no support for xp or vista, eventhough alot of people and businesses are on xp
zerocool84
36,041
472
Vista is still supported and well XP is extremely old so I don't know why you'd expect support on that.
SlitheryDee
17,252
19
The only problem I have is that the participated threads page won't load 75% of the time. I can get it to load sometimes by killing and reloading the process a few times. It only seems to happen on 3g.
Dec 30, 2004
12,553
they have your money, why should they?
meanwhile now we have every forum on the internet popping up "This forum is tapatalk enabled!" spam popup notifications when you visit a new forum you haven't been to before.
WelshBloke
33,601
11,738
Bumping this thread to see if anyone else gets the random quote thing?
Occasionally (very occasionally to be fair) when quoting someone Tapatalk will quote a different, random post. I've got a hunch that theres something funky to do with the thread IDs going on. Maybe its do do with the forums changing software a while back (all the wrong quotes seem to be very old).
My problem is that I'd need to be on my phone using Tapatalk and then check out the error on my PC to see whats going on. I've usually forgotten about the problem by the time I get home.
It also apparently happens when you use the report post to report spam as well. :oops:
olds
50,128
781
Random FCs when signal gets weak No idea what an FC is
Above plus when it lists threads, it will sometimes list the same threads 2 or 3 times.
Puddle Jumper
2,835
Taptalk HD isn't any better, often it is unresponsive when you switch back to it from multitasking and you have to kill it off and reopen it. It also suffers from the random quote issue and will occasionally mark all threads as read for no apparent reason.
s44
9,427
16
I haven't had any of these issues. But you should probably report them in the Tapatalk dev forum, where they actually do try to verify and fix bugs.
WelshBloke
33,601
11,738
Do you just get them on this forum or on others as well?
Have you got an unquotable post that you can remember?
